Question about Acer Altos G510 Server
Alarm is going off. When I open it and look at the 6 hard drives inside the top one doesn't have a green light on, instead it is flashing orange and green. How do I fix this?
Posted by eyestaff on
Jeff McFee
    New Friend:
When it flashes Green and Amber you don't need to do anything - this is rebuilding the data on that disk from the RAID array. Your server should continue to work normally.
If it stops flashing green and goes only amber then this would indicate the drive has failed and will need to replacing. Unplug the bad one and pop in a new one, and let the RAID array populate the disk - should handle this itself.
Posted on Jul 08, 2011
W.L.
  • 2,509 Answers
Remove the drive and clone it to a new one or use the raid software to rebuild to a new one.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 25, 2011
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4200 flashes orane 5 times
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
time(s) setting).
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
5 times Orange (Alarm) Destination settings [hth: not applicable]
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printer reads "Waste Ink Near Full"
www.fixyourownprinter.com/forums/inkjet/50418
The above link will assist you.
any changes.
[hth: if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work. If anyone knows how to defeat this error, I would like to know.]
Aug 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
All alarms go off; 1 of 6 alarms has a flashing green light
Your alarms are interconnected, meaning when one alarm goes off, they all go off. The alarm with the flashing green light is the one that triggered the alarm. If it only went off once, it was probably just fluke thing, and you can reset the alarm memory (flashing green light) by pressing the test button. If it happened more than once, you should try cleaning the alarm. Do this by removing the alarm, and blowing compressed air into the sensor opening (located around the back side perimeter of the alarm). If this fails, replace it.
Aug 09, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
in servicing.
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Acer Altos G510 Server Logo
212 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
