Hello jo_anne1977, the most likely reasons that the Computer "do not recognize" the "DVD ROM! If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Make sure that the dvd is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Close all open programs
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps don
