Watches Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking to adjust the size of a metal clasp style Jules Jurgensen watch band.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 25, 2011
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813011
Points
13579
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
I have a gold finish Jules Jurgensen ladies watch with a broken butterfly clasp,how can I get the clasp replaced?
Jules Jurgensen Watch Repair - Free Shipping & Estimate
Ad·www.watchrepairsusa.com/
Restoring Excellence To Your Watch. One Year Limited Warranty. Genuine Watch Mfr. Parts. Expert Craftsmanship. Free Insured Shipping. Services: Crystal Replacement, Watch Repairs & Service, Watch Restoration, Pocket Watch Restoration, Seals/Gaskets, Tune Up.
Common ServicesNo Problem Too Small
Tune Up, Overhaul, Battery & More
FAQsGeneral Questions
Shipping & Security
Jules Jurgensen Watch Repair, Overhaul/Movement, Crystal ...
https://www.totalwatchrepair.com > pages > jules-jurgen...
Maintained stock of Jules Jurgensen name parts ... Vintage Quartz Square Women'S Watch Black Band For Parts/Repair, #7730 Women'S Watch Clear Crystals ...
1helpful
Can i get a phone no. for jules jurgenson co to get extra band pieces because my watch is too tight to wear
mcdevito75 Here, I did a Fast Search and found a customer service number for Blue Dial a Jules Jurgensen Dealer, nothing on the main company though. Blue Dial may be able to help, it"s a toll free number, 1-877-518-9396 Hope this helps.
Where can i place an order for jj watch band (5001YG)
The only place you can get an original band for a watch is from the actual watch vendor. If its more then a few years old, it may even be discontinued.
Jules Jurgenson Corp (610) 667-3500
101 W City Ave
Bala Cynwyd, PA 19004
Good luck.
I own a gold tone diamond accent jurgensen(like the silver tone) and I need to replce the interchangadle 1 piece watch band. It's hard to read the watch case # but I think it's 7324QS. My current watch...
you can buy on line try ebay extra long strap 8mm or through the manufactors you should have no problem state buckle color as well a company called Hirsch sell high quality straps and bracelets they surply most of retail high end companys with their straps.
1helpful
Watch Instruction manual
The best thing to do for instructions for a Jules Jurgenssen is to contact them. You may also try retailers who carry their product.
Jules Jurgensen Helbrose International
101 West City Avenue
USA
Corporate Phone: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-220-1233cb_transparent_r.gif
Sep 22, 2009 • Watches
Dont know how to open the case of my jules jirgensen pocket watch
Its like a clasp just use a knife an open it at back case you can groove where you placed the knife tip.
Hope it may helps:
Replacement for the folding clasp
Go to this link and identify your closest retailer. http://www.julesjurgensen.com/Retailer.asp They should stock many items and be able to get all others if still in stock. If not then most jewelers could make one up, perhaps as good as the original, but i would expect it to be quite pricey. Hope this helps :)
Top Jules Jurgensen Watches Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
