Question about Iomega 1TB Desktop USB 2.0 Hard Drive
HI... Can I clone my internal drive (which is just about full) to my Iomega 1TB external drive...? Thanks
Anonymous
    New Friend:
  • 80 Answers
Http://www.runtime.org/driveimage-xml.htm this program will allow you to clone your hard drive directly to your external, you can then expand the partition using 'disk management' which can be found typing it into the 'run' window from the start menu. this will erase the external drive however and i wouldnt recommend booting from it externally.
Posted on Feb 25, 2011
1helpful
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
My iomega 1tb external hard drive accidentally plugged the 110v to 220v and its stopped working. My i omega is dead and no light, how do I fix this
At the least it will be a new power supply. Does it have an external PSU or is it internal? It depends on the quality of the power suply wether any further damage was done.
Either way if you need the data you could open the drive case up and remove the drive from it, you could then fit it as an internal disk on a desktop PC to get the data back. Opening the case won't matter as you have voided any possible warranty by changing the supply voltage.
I have just purchased a 1tb Iomega Select external HD
please change the boot setting in BIOS to hdd first then other and save it .... now try to connect the external hdd to pc and switch on .......................... ( make sure your internal HDD should be first boot able device .......)
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
2answers
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Hi Would you tell me how long 1tb IOMEGA hard drive formating will take?
It depends on how it is connected to the computer. A drive connected through an eSATA port should be able to format 1TB in just 1 - 2 hours depending on how loaded the system is (background processes/services, other use while it is formatting, etc). If it is connected via USB2.0, you are looking at approximately 6.3 times longer or up to 13 hours.
If you could reach and constantly maintain the theoretical maximum throughput on eSATA, it would only take about 45 minutes.
1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
Top Iomega Computers & Internet Experts
Ekse
 Grubhead
Grubhead
Paul Bade
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
