Question about Electrolux AWF1220 Front Load Washer
The washing machine Electrolux AURUM16 Problem with the Electrolux AWF1220 Front Load Washer The washing machine Electrolux AURUM16 was running and was shaking tremendously when out of fear I switched off the power supply and since then I am not able to open the front door and even by powering on the device seems to be not functioning, seeking help and suggestions here
SOURCE: he washer
hi there,
can supply me the brand and model # off your washer please?
Posted on Sep 24, 2008
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
Posted on Aug 18, 2011
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Posted on Sep 22, 2011
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
