Disconnect power cord to your receiver and wait about 3 to 5 minutes before do this step
If you can find on the back side of your receiver use to have a small button recess hidden behind the back cover, use a small paper clip push this this button.
Another way if you can not find the button, disconnect the power cord about 15 minutes may reset all your programs in receiver memory.
SOURCE: Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
SOURCE: how to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
SOURCE: Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
SOURCE: Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
