Question about IBM ThinkVision L151 15" LCD Monitor
I have a IBM L151 LCD monitor which is 2 years old. recently while starting all of a sudden the monitor started displaying images in green color only. Secondly the horizontal images get restricted to half screen (Remaing 40% image is blank) I have tried all possible menu adjustment but nothing works. Please suggest???
Posted by claudedsouza on
Dexter Faustino
    Scholar:
  • 122 Answers
-try the monitor on another computer and see if it will be having the same problem
-if same problem w/ a different computer it need repair
-if not the computer that you are using w/ this monitor has a problem w/ the video card --try reinstalling the video card driver
cheers
Posted on Feb 25, 2011
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
IBM monitor out of range
Change your resolution to something lower. Sounds like your video card is overdriving your monitor. Reset your resolution to 800 x 600. If that works ok, you can push it a little higher.
Mar 12, 2014 | IBM ThinkVision L151 15" LCD Monitor
Dim problem
Here is the link to the monitor's User Guide. Page 2-3 explains how to use the On Screen Display (OSD)
Dec 09, 2013 | IBM ThinkVision L151 15" LCD Monitor
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
IBM thinkVision
Could be the invertor board is bad and will need replacing.
Jun 16, 2007 | IBM ThinkVision L151 15" LCD Monitor
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
IBM ThinkVision L151 15" LCD Monitor Logo
285 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
