The wise man will choose windows password reset tool to reset windows password
For free tool, try the Ophcrack, but it would require some computer skills.
While for some affordable tool, Windows Password Reset would be the most suitable tool for you, it is even simple to use for the new beginners.
Here are the simple guide:
Step 1: Download Windows Password Reset Deluxe from http://www.windowspasswordreset.net and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows password successfully
Choose the most suitable tool for yourself. Good Luck.
Here is the step to Clear Password
Method 1: Use a password reset disk
To log on to the computer by using a password reset disk, follow these steps. If your computer is or was a member of a domain, go to the "Windows XP Professional in a domain" section and follow those steps.
Method 2. Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords.
You can view the article to read more.
Hope can help u
When you are booting up your computer, you need to press F8 in order to get into the per-windows start-up.
Once you are in this stage, you will need to boot your computer into safe mode. This will give you access to the basic programs of Windows XP.
Once you have booted into safe mode. You will have to access the administrator account and create a new account or you can reset your admins password from this location.
Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
also
hope this helps
If you are referring to a system password, and not the windows password (IE - power on password) it is reset by the password jumper (25) near the power connector.
