In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
In most of htese cases it is good to have a reset to see if the driver software has errors. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
If the driver software is corrupt it can show wrong readings of the ink levels So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
A possible reset might solve hence remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
