If you are unable to change the IP address of your Zebra LP 2844-Z using the ^default command or Zebra Utilities, and updating the BIOS did not help either, you may need to try a factory reset of the printer.
To do this, follow these steps:
Turn off the printer.
Press and hold the feed button on the front of the printer.
While holding the feed button, turn on the printer.
Wait for the status light to turn solid red, and then release the feed button.
The status light will blink green a few times, and then turn solid green.
Press and release the feed button once. The status light will blink red a few times, and then turn solid amber.
Press and release the feed button again. The status light will blink green a few times, and then turn solid green.
The printer should now be reset to its factory settings, including the default IP address of 192.168.168.168. You should now be able to access the printer through this IP address and change the settings as needed.
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manualthen you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Hello Look at the number of blinks of the status light. [1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly. [2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position. [3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly. [4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again. [5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
I look all over the net but could't find anything, until i found a site that said they could show me how to fix any problem with my ps3. At first i was not so sure about ordering the manual but i did, whats $5 plus i used paypal, but long story short i fix my ps3, i recomend this site www.gameme.20fr.com i hope this help you like it help me.
According to the manual, yes . . .probably gone past the recommended hours of lamp use. Press the OFF or the HELP button on the remote for 10 sec, this will reset the lamp hours value and allow the unit to come on. If it don't, NEC will tell you that it has to be sent to a repair center.
