Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these . these codes are for older models that use codes like these 12 35. the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected. the next code 35. this code means loss of prime, code # 11 means internal transmission failure. the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
P0700 means transmission control fault detected,either it is mechanical or electrical.This code is a generic code,you will need a enhanced code that mean a manufacture scantool or a scan tool that can read enhance code.
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site Unlock-free.com/nokia/nokia-7210.html and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
it locked to Network?Security code? Do you need to Unlock it? What is Mobile brand and Model? It nokia means locked to security code means try 1234 or 0000 as default code and unlock it...It locked to Network lock ,you need to unlock mean you can get the Unlock code at here Theunlockspot.com and unlock it.....If it nokia means you can get the master reset code there and reset from password or security lock,Also there you can get the master reset code for Alcatel Phones...It locked to PUK code, means get from service provider and Unlock it..
What Code You need to Enter whether it's Network Unlock code or Security Unlock code,Network Unlock code means You can reach here Classicunlocking.com get the code and instructions there and Unlock it from Network Lock,Using the instructions You can enter the code step by step...then it asks for security code means It's Nokia or alactel means get the master reset code there and Unlock it using the instructions they provide through mail....You can try default code for Nokia 0000 or 1234 It not works means get the master reset code there,then other brand Phones get the master reset code and instructions from Service provider....
What code Network Unlock KEY or Security Key? Network Unlock key means specify the Mobile brand and Model? You can get the Network Unlock code and Unlock it...then it asks for security code means you can better reset the Phone using the master reset code ,if it Nokia means try 0000 or 1234 It not work means use You can get the master reset code and reset it,.You can get the Network Unlock code and Master reset code from here Unlocking4free.com and Network Unlock it..
It's asking for NP Code means Network provider code,that means Unlock code,If the Mobile locked to other Network means you trying to insert other Network Sim means it asks for Unlock code or NP Code,Unfreeze Code,subsidy code,Special code,NCK code,MEP Code etc...It depends upon the Brand of Mobile..so specify the Mobile Brand ,model,network,country it locked now,IMEI number and get the Unlock code at Unlocking4u.com and Unlock it...
