Question about Timex T5K018 Ironman Triathlon 30 Lap Flix Watch
I have set the 2nd time zone, but I can't set the watch to display the 2nd time zone.
Posted by joelhmorris on
Joey Cothran
    New Friend:
Had the same problem when my niece was playing with my watch and switched time zones and I couldn't find the paperwork to switch it back. After not finding the solution online I played around with the watch and figured it out. Just hold down the start split button till it switch zones. It will beep when the switch completes.
Posted on Nov 03, 2013
TheGoldenMinecart
    New Friend:
Does anyone know how to set the second time zone?
Posted on Aug 23, 2015
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Apr 29, 2014 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have a pulsar nx14-x003 watch with world time zone ect.. My problem is the digital time has dissapeared, the anolog time still works, as does the stopwatch ect.... When I edit the time the digital time...
Hi, maybe You just holded reset button at basic display mode. With 1st pressing and holding it for few secs You can make digital time disappear, 2nd holding makes disappear upper display, and 3rd time You are back with both displays on.. ;) Just bought them from eBay and lazy to read manual..its a nice watch indeeed :)
peace
Dec 30, 2012 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
How do i match the digi time with the hand time?
Some Renato anidigis are world timers tracking second times and time zones. On my Vulcan World timer for example, pressing the crown allows you to select and set a second city and time zone for the digital display while the analog dial continues to show the primary local time you entered when you did the initial setup. If you want both displays to show the same time, simply set the same city for both displays. To set the secondary digital display on mine, after pressing the crown, CITY would blink, and I would choose the same city and time zone again rather than let the indicator rest on a different one at random.
Mar 20, 2011 | Renato T-Rex Ana-Digi Watch for Men
How do change the date on my citizen divers watch
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy Instructions
  1. Pull the setting knob (crown) out one "tick" for setting mode.
  2. Set the mode hand to "WT-S."
  3. Pull the crown out one more "tick."
  4. Press the top button on the right side of the watch for the city setting mode.
  5. Press the lower button on the right side to "SET" the city.
  6. Turn the crown to select a different city, which changes the time zone.
  7. Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
Feb 21, 2011 | Citizen Watches
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Setting the independent hour hand on a Rolex Explorer II
It should be the 3rd position on the crown: 1st date, 2nd hour, 3rd time zone. And don't take it to a "jeler" like jamison said. If you cannot do this watch is fake.
Sep 20, 2008 | Rolex Explorer II 16570 Wrist Watch
How do I set a LaCrosse WT-961 (B) watch?
This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
Mar 07, 2008 | La Crosse Radio Controlled Watch
Timex T5K018 Ironman Triathlon 30 Lap Flix Watch Logo
365 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
STEVE yes that one
Are you a Timex Watch Expert? Answer questions, earn points and help others
