Hi Jamie hig595, I suggest that you check around both machines to see if you can see any oil stains,: ie: inside the outdoor unit, where the pipes are connected to the outdoor machine and indoor machine, or even around the outdoor case itself. Any oil stains would suggest that your system has lost gas and therefore you will need a serviceman. If thge machine will run at all are the fans working? hope this is helpful,regards Col
No visible oil stains. I found another solution posted suggesting it could be:
"Outdoor unit PCB EEPROM failure....try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable."
