Question about Jabra Stone Bluetooth Headset
I can pair my Jabra Stone to my computer, but I can't figure out how to connect my computer's audio to the bluetooth "port"
Posted by Clint Meneely on
  • 3 more comments
  • Clint Meneely Feb 24, 2011
    I already paired my Jabra with the computer using a bluetooth dongle.
    When I click on the bluetooth icon I can see the Jabra Stone and when I click on "properties" it tells me that this is a "Headset (Audio Device)"
    However, when I go to the services tab it searches and comes up with nothing.
    Do I need some special driver to hook up the audio with the bluetooth?
    - Clint
    OK I installed the Jabra PC Suite, but no joy.
    Is there something I have to activate?
    - Clint
    Sorry, I forgot.
    All I want is to use the Jabra Stone to deliver the PC's audio to my right ear - my left ear went deaf for no obvious reason about 10 months ago.
    My computer uses the Windows XP operating system
  • Clint Meneely Feb 25, 2011
    Ezrahite - Unfortunately, the Jabra doesn't show up on the sound control panel.
    It's like the PC recognizes the Jabra as a connected bluetooth device, but doesn't know what to do with it.
    Ezrahite - It works fine with my cellphone. The pc just doesn't show any services for it when it is connected,
    - Clint
Rofel Lantican
  • 2,632 Answers
Welcome to Fixya. Yes you can pair the jabra headset to your computer given that the computer has a bluetooth device install on it. Follow the steps below on how to pair the jabra headset to your computer.
1. Turn on your Bluetooth device on your computer.
2. Click "Start," then choose "Control Panel."
3. Double-click on your Bluetooth icon and go to the "Setup" option. It will open up a wizard.
4. Walk through the wizard. In it you will need to place your Jabra Bluetooth headset into a finding/transmitting mode. You will hold down the button on the Jabra headset until it is blinking a solid green.
5. Click "Next" when it is time for finding any Bluetooth devices in the area. This will then find your Jabra headset because it was set up in the previous step.
6. Click "Next" once the devices are paired, and use the headset at anytime.
Thanks for using Fixya.
Posted on Feb 24, 2011
  • 2 more comments
  • Rofel Lantican
    Rofel Lantican Feb 24, 2011
    What application do you want to use the jabra headset? What operating system are you using? If you need a driver for the Jabra Headset click on the link below. You can also find there the tutorial and installation guide.
    Jabra PC Suite
    Thanks
  • Rofel Lantican
    What operating system are you using? can you go to control panel then go to sound. Can you select the jabra headset and set that to default?
  • Rofel Lantican
    Rofel Lantican Feb 25, 2011
    Clint have you tried to connect the Jabra headset to your mp3 or mobile device see if it works? because basically after you pair the headset you will be able to use it like pairing it to a mobile phone or mp3
  • Rofel Lantican
    have you tried to use it with skype and try to check if you will be hearing something?
Where can I get a user manual?
Hi Robert
See if Jabra Have One.... Search the Internet
You Bought Jabra.... One of the Best... so
They should have support
As in their Video Here
How to pair Jabra BT2045
EasyGo Jabra Headset Bluetooth Android iPhone
Feb 25, 2016 | Jabra Stone Bluetooth Headset
Dont no how to pair order on ebay no hand book
this is for the stone 1
http://www.jabra.com/sites/mobile/na-us/support/pages/pairingguide.aspx
this is for the stone 2
what phone are you trying to pair with the bluetooth headset?
the default codes for jabra headsets are 0000
Mar 01, 2011 | Jabra Stone Bluetooth Headset
The jabra stone device will not pair with my mobile phone. It was paired at one time but has since quit working.
Depending on the phone, Some phones need to be set to be visible so that Jabra can find it when it is ready to pair.
I would delete the paired entries on the phone and do a fresh pair to the phone.
Do let me know if you are able to do this or can chat and walk you thru.
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
Feb 24, 2011 | Jabra Stone Bluetooth Headset
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 15, 2010 | Jabra Stone Bluetooth Headset
Even after charging the jabra stone does not come on nor pair
I am having same problem. Stone seems to be charging, but headset will no longer operate. Have used successfully for 5 months.
Sep 15, 2010 | Jabra Stone Bluetooth Headset
How do i pair the jabra stone with the iphone 4? seems like i cant pick up anything from it when its in pairing mode.
Just did it myself. Ensure the iPhone is discoverable and searching.
Switch the Stone off by squeezing down the control surface until it bliddle-omps.
Put it into pair mode by squeezing the thang again until the bluetooth light flashes. Keep squeezing.
Watch the iPhone - it will pair automatically - no password required.
Sep 03, 2010 | Jabra Stone Bluetooth Headset
Jabra Stone Bluetooth Headset Logo
542 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
