Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no help on error code found.
Posted by ricky_matney on
Shawn
  • 200 Answers
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Posted on Feb 27, 2011
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Howdo i hook up the scanner to my pc??
You need to call a Kyocera or Copystar Technician.
Jul 15, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera 3035 under res. i get e023
The KM3035 requires a second network card for network scanning. then use the scanfile utility on the client machine / server to recieve the jobs and dump in a shared folder
Apr 01, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
How do you enter fax numbers into the address book
send me your email to send you the directions from the manual.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Stapling from the print mode
Yes, look in the printer properties in control panel to set this option before you print.
Nov 19, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Error code E022 on a 3225 model printer/scanner
This error is telling you the SMTP server does not understand the email address typed in by the user
Check that the destination address has been correctly entered
Aug 28, 2008 | Kyocera Office Equipment & Supplies
KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Oct 15, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
1,823 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
