Ok i dropped it like 3 times n in the back for the umd the metal part came off on the right..and i tried playing a game it wouldnt load so i called the people fopr the playstation thing they said send it to them..and my friend said let gamestop fix it.so wat should i do
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Get it modded it's very cheap $20 - $40. You will still be able to play games just look it up "PSP mod" on craigslist.com and you should be able to find something.
If your PSP isn't reading
games and/or movies and the problem isn't that your trying to play
dirty, bent, or damaged UMD discs there are a number of other reasons
your PSP is not reading disks correctly = - Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we
will get your PSP back to you and playing like like new fast! Our price
includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
your son probably dropped his PSP at the time and the UMD drive broke or if your son says he didnt drop it you can get a cutip and softly clean your UMD reader the little bubble sorta in your PSP be carful while doing that
You need to look intothe UMD drive. Press the little Black probe sticking up in the UMD drive. It is about 3/4 inch from left and 3/4 inch from top of the UMD drive. When you press it, look for the Disc spindle to rotate, and the Laser to light up and the Laser movement to occur. This will tell you a lot in what is working or not in the UMD drive. If the laser does not move left and right, or light up, you have a problem with the laser. move it manually with a pen or something, Only click it a couple of times. Try the black button thing again. If the Disc spindle motor does not spin. You probably need a new UMD drive. If you need a new UMD drive, click on "repair directory" at the bottom of this screen, Click on Video game Consoles. Pick out a good service out. I know one of them specializes in Playstations.You can get a new UMD drive replaced for under $60.
Make sure the UMD is
properly inserted with the label facing the back of the PSP system.
Try removing the UMD and reinserting it.
Try playing the UMD on a different PSP system. If
the UMD plays, the original PSP system may be the problem. If the UMD
does not play, the problem may be isolated to the UMD itself.
Try playing
a different UMD on the PSP system. If another UMD plays, the original
UMD may be the problem. If none of the UMD's play, the problem may be
isolated to the PSP system.
Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
