Nokia 2720 Fold Cell Phone Logo
Anonymous Posted on Feb 24, 2011
Mms/wap - Nokia 2720 Fold Cell Phone
JASEEL P
Level 3:
  • Master 556 Answers
  • Posted on Feb 26, 2011
JASEEL P
Master
Level 3:
Answers
556
Questions
Helped
128838
Points
2042
MMS seetting required for using MMS serviece(GPRS seetting and MMS setting is different).
To get the MMS setting please call your service provider.
They will send you the MMS setting.After you receive please save the settings to your
phone.
Then you can start send and receive MMS without ant problem.
Good Luck.
Thanks for using FixYa.
  • khan shadab Apr 12, 2011
    pls customer care my nokia 2720 gprs setting sent my mobile mobile tata docomo 9029799491
6helpful
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 • Cell Phones
1helpful
2answers
How to communicate or activate my gprs?
hello beljohn,
i have some tips for your question hope this helps
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
1helpful
How to activate the gprs of nokia 1616
it depends on your carrier for Sun Cellular
Setup/Enable GPRS
Select Sun GPRS
APN: "wap"
Select SUN MMS
APN: "mms"
Setup/Enable MMS
Proxy Port: "8080"
Setup/Enable WAP
Proxy Port: "8080"
Mar 07, 2011 • GPS
1helpful
How can i view my mms picture?
This handset supports mms (multi-media messaging) as long as it is in one of the following formats, Supported formats : image/jpeg,image/gif,image/png,image/bmp,image/vnd.wap.wbmp,audio/midi,audio/sp-midi,audio/mid,audio/iMelody,text/plain,application/smil,application/vnd.eri.thm,application/vnd.wap.mms-message,application/vnd.wap.multipart.mixed,application/vnd.wap.multipart.alternative,application/vnd.wap.multipart.related,application/vnd.oma.drm.message,application/vnd.sem.mms.protected,application/vnd.oma.drm.content
If it is in the supported format, then you can retrieve it if you have the wireless internet service through your wireless carrier. The ability to send a text message does not constitute internet availability. Text or SMS does not run on the same platform as mms or WAP, which is the wireless internet ability. If you are not able to retrieve the mms message when you select it, you will need to contact your wireless provider.
1helpful
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 • Cell Phones
Text messages
i can provide you with this if you tell me what Cellular provider you are using, ATT, T mobile.I have a help disc available for 10 us dollars. if interested can paypal to [email protected] our included CD you will receive the following: over 1000 ringtones - over 1000 wallpapers - user manual and FAQ - video conversion software - MP3 to ringtone converter - Settings for every USA, UK, and most of World GSM service providers - Automatic internet setup - Automatic configuration of MMS settings - Beginner Guides and Tutorials Detailed item list for CDInternet, GPRS, MMS, SMS setupAUTOMATIC SETUP OF MANY PROVIDERST-Mobile USA, SMS MMS Internet Setup (T-Mobile for Dummies Guide)MMS for T-Mobile USAT-Mobile U.S.A. GPRS/EDGE, ISDN, and WAP settingsT-Mobile MMS & Internet for GermanyUK GPRS set upMMS settings for ALL UK providersGPRS Settings for ALL UK providersWAP/Internet Settings for ALL UK providersUK Orange MMS SettingsATT/Cellular OneInternet & MMS for Netherlands Orange NLMMS and WAP for Rogers in CanadaMMS/GPRS Settings for Boost/Optus AustraliaWAP in Australia on 3 or 'Three' Network!ITALY MMS/WAP TIM Final SettingsItaly Vodafone/TIM MMS WAP settingsFIDO Internet settings CanadaFIDO MMS settings CanadaClaro Internet & MMS settings - Puerto RicoSMS, MMS, & Internet for Unicel in VermontMMS WAP settings FRANCE providersOther Softwarevideo convertermp3 to ringtone converterOver 1000 WallpapersOver 1000 RingtonesBeginner guides
121helpful
9answers
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
1helpful
Problem..
reset your phone on factory setting
1helpful
4answers
Unlocked european phone MMS
wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Homepage: http://device.home
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: [email protected]
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Server Name: http://mmsc.cingular.com
Web Session Name: (Choose the Web Session you created for MMS)
set to default
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
