Computers & Internet Logo
Question about Acer Crystal Eye webcam
My Webcam doesn't function. whenever i try to use it, "Not found" is the answer what can be the problem? i have tried looking for the appropriate drivers on the internet but i have failed. Benard
Posted by benardotieno on
Anonymous
    New Friend:
  • 72 Answers
You will need the exact drivers installed for it to work. They will be available on the Acer website, just find the model of your laptop & you should see a download drivers/software then select camera.
Posted on Mar 02, 2011
1helpful
Toshiba webcam doesn't work
You could try downloading and reinstalling the webcam driver.
Get online and got to www.google.com In the google search box type: "Toshiba Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Webcam drivers.
You can always download Manycam and install it. Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on the left and you will see a gray area that says Find Software. Type "Manycam" (without the quotes) in the white search area then hit the search mirror. When it brings back your results look for the one that says ManyCam Virtual Webcam. Down load it and install it. Make sure you remove the check box on any junky programs it would like to install. You only want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where your webcam software is.
1helpful
The built-in microphone on Acer Aspire one 6920g doesn't work
Have you checked the webcam software to make sure you have the volume turned up for the microphone?
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the webcam drivers.
Try using ManyCam. It comes with drivers and software to drive it.
You can also visit their site to see how to use it when ever you want to skype or use some other function that requires the webcam.
http://www.manycam.com
Hi there, My Crystal Eye Webcam stopped working. I have re-installed from the original on the HDD it tells me ok. Skype can't find it. In Device Manager it's not visible. I also tryed to start...
Try downloading and installing the newest drivers for the model of your computer.
http://www.acer.com/worldwide/support/download.htm
If this doesn't fix it, make sure you are not using any programs like ManyCam or anything that would be using your webcam. You can only use the webcam in one program at a time.
How can I graph sine and cosine waves on my TI-84 Plus? I can see the Theta symbol on the "X,T, "Theta",n" button. But whenever I try to graph a function, it doesn't work. Please...
When you graph functions y=f(x), even if f(x) is a trigonometric function, the default independent variable is x. You will have to use the variable theta only when drawing polar functions.
To draw the sine and cosine or any other trigonometric function set the angle unit to radians and window zoom to standard. If your angle unit is degree you must modify the x-window range to, say, multiples of 180 degrees. Other than that there is nothing special to do. The functions are well-behaved and should graph nicely. You will alos get a better view if Ymin is about -1.2 and Ymax is about 1.2
Hi, i have a sony DSC-S730 digital camera. until recently, i was able to copy pictures from the camera to my PC, but now whenever i try copying, an error message pops up saying "cannot read from the...
Take off the SD card and try to copy from other SD reader with connected at PC; if this isn't work, then you should try formatting the card. If that doesn`t help, it looks like the card is faulty.
Its possible that you lost the pics in there.
4helpful
My webcam Acer Aspire 4732Z , " not found " at
you need to install webcam driver for win 7. If you already have you try to reinstall the driver. If you need the drivers you can get it here
You may contact me if you need more helps..
please help to rate me if you think this is useful
Couldn't open the built-in webcam
try to reinstall you webcam drivers. usually when you purchased the laptop it came with driver disk. look into the driver disk and install your camera software driver
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Steve Sweetleaf
Steve Sweetleaf
shadow
