I never encountered this problem, but if you turn off WiFi when not in use the battery lasts longer. Also go to settings, battery, and check what is using the most power.
I don't understand. The camera should prevent itself from overheating. When the camera becomes to hot it will switch off itself. If your camera is switching off more than once, something could be wrong. But if not shooting continues of filming for a long scene in a normal environment the camera must work ok. Photo cameras are not make to capture films for more than 10 minutes. That will overheat the sensor. When shooting in full sun light we try to put the monitor on full brightness. That also will warm up the camera. And can bring it to shut down. It will also exhaust the battery quickly.
Be sure to charge your batteries fully before installing them. If the batteries are non-rechargeable, dispose of the old batteries properly, and then replace them.
Rechargeable batteries have a limited number of charge/discharge cycles before they become exhausted. If your rechargeable batteries are dead after a full charge cycle, they may also need to be replaced.
a bad converter will give off a "rotten egg" smell, restrict the exhaust & cause the engine to operate at a hotter temperature, the heater will be excessively hot, the radiator or heater core could begin to leak, hoses will have extra pressure on them & there will be blow-by fumes forcing their way back from the exhaust maniforld into the engine if the converter becomes too plugged. This causes your motor oil to become dirty much more quickly too, causing extra wear on the engine You can generally see a very rusted exhaust behind the converter once this has happened. You'll get a miss, followed by sputtering & eventually either a frozen motor, blown headgasket, cracked head, or other problems caused by heat. good luck
Ok, check the exhaust hose for obstructions. make sure the blower assembly is not clogged and, the hose is clear of any debris. the exhaust hose should blow out hot air forcefully. if the force of the air isn't blowing hard, it will not create a suitable drying environment for the element. this poor ventilation will also damage the heating element or burner Assembly.
Now, if there is sufficient air flow out of the exhaust hose, this will confirm control failure. replace the dryness sensor and control board in this case.
Here's a quick way to test for clogs. take the hose of the backside of the dryer then, start the cycle. if the drum sorts to become hot after a few minutes with the exhaust hose removed form theback of the unit, this will confirm a major block in the hose or blower assembly.
In addition to the batteries provided with the camera, the following types of battery can be
used. Choose the power source best suited to the situation.
AA alkaline batteries/Oxyride batteries
The number of pictures that you can take may vary considerably depending on the battery
manufacturer and shooting conditions.
AA NiMH batteries (rechargeable batteries)
Olympus NiMH batteries are rechargeable and economical. For details, refer to the
instruction manual for your charger.
(Lithium battery packs (CR-V3) and AA manganese (zinc-carbon) batteries cannot
be used.
(Power consumption by the camera varies depending on which functions are used.
(Power is consumed continuously during the conditions described below causing batteries
to become exhausted quickly.
• The zoom is used repeatedly.
• The shutter button is pressed halfway repeatedly in shooting mode, activating the auto
focus.
• The monitor is left on for an extended period of time.
• The camera is connected to a computer or printer
(The battery life varies widely depending on the type of battery, manufacturer, shooting
conditions, etc. Because of this, there may be cases where the camera turns itself off
without displaying the battery level warning, or displays the battery level warning sooner than usual
Actually I have this camera and one that didn't stay on without fresh batteries every few minutes was given to me to tinker with. It is a software problem and if you are patient and follow the directions exactly...a simple firmware upgrade should resolve this issue for you.
Go to: http://www.general-imaging.com/us/firmware.html
Locate the blue box on the left that says QUICK LINKS and then click on FIRMWARE UPGRADES and locate your camera model. I hope this is helpful.
