Computers & Internet Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm planning to upgrade the firmware in my HPR5500 XR to version 2.06. The problem is I need to know the rev number of the current firmware in it. How can I determine that?
Anonymous
Level 3:
  • HP Master 1,591 Answers
  • Posted on Feb 24, 2011
Anonymous
HP Master
Level 3:
Answers
1591
Questions
Helped
413827
Points
4899
There's really only 2 possibilities here, older than or newer than 2.02. The upgrades are as follows:
For version 2.02 and above run the following batch file:
Flash_5125_6K_from_v0202_or_v0204_to_v0206.bat For version 2.00 or older run the following batch file
Flash_5125_6K_from_v0200_or_older_to_v0206.bat
I would try the newer one first and if it fails, then use the older one. (logic being, the newer one will check the revision, and if it's too old, won't do the upgrade)
Once you have successfully upgraded to 2.06 I highly recommend upgrading to 2.08 (you must do the 2.06 upgrade first though!)
I have a LG K20 Plus that is currently running Andriod version 7.0 Build number NRD90U Software version MP26011e. Is there anyway to upgrade to version 8?
The OS upgrade is controlled by the phone manufacturer.
You can look through LG's website to see if they plan any upgrades.
4helpful
D-Link DI-514 Router Firmware Upgrade Error Message
This is an old post, but just in case someone else needs this...
The dlink website for the Di 514 rev B version actually links to the rev C versions' firmware. I got the same error.
browse to here ftp://ftp.dlink.com/Gateway and grab the right version for your rev B device.
Best,
Kevin
1helpful
DAP-1522 WIZARD
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
1helpful
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
SOLUTION: For Windows XP and Pioneer DVR-K16 DVD Drives
Dial +1-800-204-4427 and Get end of support information for Windows XP and find out what you need to know to upgrade to Windows 10 or find a new PC.
1helpful
How to upgrade the firmware on my Canon XS
You can go directly to the most recent version without installing the intermediate versions.
Load up to 20% then shuts off
Hello Dear:
you need to upgrade your firmware version by going the samsung site and search your player model number and download the current firmware instal the setup in your pc and connect your player in the pc usb but remember your player is still powerd off
and upgrade the firmware Thats it
How do I know what my firmware is?
One way to find your current firmware installation is to login to your router using http://192.168.0.1 , then enter your username and password. (If you're not sure of these, check the label which should be on the base of the router.)
Click 'Maintenance' from the main menu, then 'System Status'. The firmware version should be under 'Router Status'.
Sorry, not sure what the 1 or 11 means...but you might need to know the version number of your router, so again check the label on the base of the router: you should see WGT624v2 or something similar.
When you know the version number, visit the Netgear website and select the Support Page for your version number:
http://kbserver.netgear.com/products/WGT624.asp
This will tell you the firmware available for your router.
If you need to upgrade firmware, it's best to proceed very carefully! Use a cabled connection, and take a backup of your settings, as advised in the manual. :)
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
3helpful
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
