Question about Sony PlayStation 2 (PS2) Console
My ps2 will onlt load games with blue on the bottom of the disc and not load the silver games. the discs are not scratch any idears on whot to do.
  • Anonymous Feb 24, 2011
    all original discs
Anonymous
    New Friend:
  • 3 Answers
IF THE ONE WITH BLUE ON BOTTOM IS ORIGINAL AND THE ONE WITH SILVER IS PIRATED,IT MEANS THAT UR PS2 ONLY LOADS ORIGINAL DISCS. HAVE U TRIED LOADING ORIGINAL DVD WITH SILVER BOTTOM?
Give more details on ur problem (whether u r not able to run duplicate dvd or can only play dvds which u bought along with ps2)
Posted on Feb 24, 2011
    all original discs
PS2 will play any audio cd and any ps2 blue game disc. but it will not entertain a silver game disc or dvd. just keep getting Disc read error.
sounds like your laser is failing. You can find tutorials on how to adjust, clean or replace your laser. Do a google search for " ps22_bing.gif disc read error " it will give you a choice of plenty of tutorials to follow. Good luck
Feb 04, 2010 | Sony PlayStation 2 (PS2) Console
PS2 wont read Silver bottom games
really...mostly its the blue backs that mess up ..all i can say is if u have not already change you component video out in you configuration and change the disc speed and texture mapping.u can find that by going to the main screen and press triangle and go to ps driver and press triangle and pick the one u want to change..hope this helps :)
Aug 29, 2009 | Sony PlayStation 2 Slimline Console
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any [email protected] (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
PS2 will not read disc for Guitar Hero
theres a difference in the older guitar hero games and newer ones, CD Rom for the older and DVD Rom for the newer, Ps2 wont read the DVD Rom ones, my experiance so far.
Oct 02, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 disc problem
did u look at the disc to see if in there? If yes, maybe it was dust.
Apr 28, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Dodgy ps2!!!
yeah your laser is out of line. to correct it you have to open up your console a bit. Pull the rubber feet off the bottom and unscrew the shell, be really careful when you take the two halves apart because you have wires running between them. Then unscrew the black plastic cover over the drive and underneath you should see a large white gear with a slot for a hex key in the middle. Mark off the start position on this wheel then move it clockwise by one cog, close it up and try a disc. If it doesnt work, move the wheel round one more cog and try again.
Remember different types of disc work differently, the PS2 reads PS1 games easiest, then DVDs, then PS2 silver discs, then PS2 blue discs, so try them in turn.
If you look hard enough on the web there is a detailed explanation of this repair with photos that is worth seeking out
Nov 26, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 doesnt read some of my games
This can sometimes be caused by the actual PS2 media. PS2 discs usually have either a silver or blue bottom. Silver is DVD media and Blue is CD media. Sometimes the laser mechanism gets a little wonky and can't read one type or another. Typically, older games had the blue discs (Kinetica and Gran Turismo are some of the oldest games on the system) I would check the color of your existing games and see if that is an issue. Another possible idea is that you just got a bad disc, it doesn't happen very often but it does pop up from time to time.
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Disc Read Error-My ps2 only reads certain discs
the optic needs to be replaced ,the part cost its around 45.00 but you need to provide model,serial# and manufactured date . or you can sen the unit for a repair around 120.00. let me know if you need more info
Jun 22, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
