This behavior can indicate an issue with the battery of your headphones, as it may not be able to hold a charge or may have other internal problems. It's also possible that there's a software issue or a problem with the connection between the battery and the headphones' components. Here are a few steps you can try to troubleshoot the issue:
- Check the charging cable: Make sure the charging cable is in good condition and properly connected to the headphones and the charging source.
- Clean the charging port: Dust and debris can accumulate in the charging port, which can prevent a proper connection. Use a soft-bristled brush or a toothpick to gently clean the port.
- Try a different charging source: If the issue persists, try using a different charging cable or a different wall adapter to see if the issue is with the charging source.
- Reset the headphones: If the previous steps didn't solve the issue, try resetting the headphones by removing the battery or holding down the power button for 10-15 seconds.
If none of these steps work, the issue may be with the battery or the headphones' components, and you may need to contact the manufacturer for repair or replacement.
