Question about Canon BJC S300 InkJet Printer
Zaguben instalacionen disk - Canon BJC S300 InkJet Printer
6ya staff
SOURCE:
How to defrag on acer extensa 5620
You can use the built-in Disk Defragmenter to Defragment your system.
To defragment your hard disk
  1. Open Disk Defragmenter by clicking the Start button. In the search box, type Disk Defragmenter, and then, in the list of results, click Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Once Windows has finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
4. Click Defragment disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
GuruAid
May 05, 2014 | Acer Extensa Computers & Internet
Tip
Convert to Basic and Dynamic Disks in Windows XP
Windows XP Professional supports two types of disk storage: basic and dynamic. Basic disk storage uses partition-oriented disks. A basic disk contains basic volumes (primary partitions, extended partitions, and logical drives).
Dynamic disk storage uses volume-oriented disks, and includes features that basic disks do not, such as the ability to create volumes that span multiple disks (spanned and striped volumes).
General Notes
Before your change a basic disk to a dynamic disk, note these items:
You must have at least 1 megabyte (MB) of free space on any master boot record (MBR) disk that you want to convert. This space is automatically reserved when the partition or volume is created in Microsoft Windows 2000 or Windows XP Professional. However, it may not be available on partitions or volumes that are created in other operating systems.
When you convert to a dynamic disk, the dynamic volumes cannot be changed back to partitions. You must first delete all dynamic volumes on the disk, and then convert the dynamic disk back to a basic disk. If you want to keep you data, you must first back up or move the data to another volume.
After you convert to a dynamic disk, the dynamic volumes cannot be changed back to partitions. You must first delete all dynamic volumes on the disk, and then convert the dynamic disk back to a basic disk. If you want to keep your data, you must first back up or move the data to another volume.
After you convert to a dynamic disk, local access to the dynamic disk is limited to Windows XP Professional and Windows 2000.
If your disk contains multiply installations of Windows XP Professional or Windows 2000, do not convert to a dynamic disk. The conversion operation removes partition entries for all partitions on the disk with the exception of the system and boot volumes for the current operating system.
Dynamic disks are not supported on portable computers or Microsoft Windows XP Home Edition.
Before you change a dynamic disk back to a basic disk, note that all existing volumes must be deleted from the disk before you can convert it back to a basic disk. If you want to keep your data, back up the data, or move your data to another volume.
How to Convert a Basic Disk to a Dynamic Disk.
To convert a basic disk to a dynamic disk:
1) Log on as Administrator or as a member of the Administrators group.
2. Click Start, and the click Control Panel.
3) Click Performance and Maintenance, click Administrative Tools, and the double-click Computer Management.
4) In the left pane, click Disk Management.
5) In the lower-right pane, right-click the basic disk that you want to convert, and the click Convert to Dynamic Disk.
NOTE: You must right-click the gray are that contains the disk title on the left side of the Details pane. For example, right-click Disk 0.
6) Select the check box that is next to the disk that you want to convert (if it is not already selected), and the click OK.
7) Click Details if you want to view the list of volumes in the disk.
8) Click Convert.
9) Click Yes when you are prompted to Convert, and the click OK.
How to Convert a Dynamic Disk to a Basic Disk.
To change a dynamic disk back to a basic disk:
1) Back up all the data on all the volumes on the disk you want to convert to a basic disk.
2) Log on as Administrator or as a member of the Administrators group.
3) Click Start, and the click Control Panel.
4) Click Performance and Maintenance, click Administrative Tools, and the double-click Computer Management.
5) In the left pane, click Disk Management.
6) Right-click a volume on the dynamic disk that you want to change to a basic disk, and then click Delete Volume.
7) Click Yes when you are prompted to delete the volume.
8) Repeat steps 4 and 5 for each volume on the dynamic disk.
9) After you have deleted all the volumes on the dynamic disk, right-click the dynamic disk that you want to change to a basic disk, and then click Convert to Basic Disk.
NOTE: You must right-click the gray area that contains the disk title on the left side of the Details pane. For example, right-click Disk 1.
on Jan 19, 2010 | Computers & Internet
Tip
Convert To Basic And Dynamic Disk
Windows XP Professional supports two types of disk storage: basic and dynamic. Basic disk storage uses partition-oriented disks. A basic disk contains basic volumes (primary partition, extended partitions,and logical drives).
General Notes
Before you change a basic disk to a dynamic disk, note these items:
You must have at least 1 megabyte (MB) of free space on any master boot record (MBR) disk that you want to convert. This space is automatically reserved when the partition or volume is created in Microsoft Windows 2000 or Windows XP professional. However, it may not be available on partitions or volumes that are created in other operating systems.
When you convert to a dynamic disk, the existing partitions or logical drives on the basic disk are converted to simple volumes on the dynamic disk.
After you convert to a dynamic disk, the dynamic volumes cannot be changed back to partitions. You must first delete all dynamic volumes on the disks, and then convert the dynamic disk back to a basic disk. If you want to keep your data,you must first back up or move the data to another volume.
After you convert to a dynamic disk,local access to the dynamic disk is limited to Windows XP Professional and Windows 2000
If your disk contains multiple installations of Windows XP Professional or Windows 2000, do not convert to a dynamic disk. The conversion operation removes partition entries for all partitions on the disk with the exception of the system and boot volumes for the current operating system.
Before you change a dynamic disk back to a basic disk, note that all existing volumes must be deleted from the disk before you can convert it back to a basic disk. If you want to keep your data, back up the data,or move your data to another volume.
To Convert a basic disk to a dynamic disk:
2) Click Start, and then click Control Panel.
3) Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
4) In the left pane,click Disk Management.
5) In the lower-right pane,right-click the basic disk that you want to convert, and then click Convert to Dynamic Disk.
NOTE: You must right-click the gray area that contains the disk title on the left side of the Details pane. For example, right-click Disk 0.
6) Select the check box that is next to the disk that you want to convert (if it is not already selected), and then clickOK.
8) Click Convert.
9) Click Yes when you are propmted to convert,and then click OK.
How to Convert a Dynamic Disk to a basic Disk
1)Back up all the data on all the volumes on the disk you want to convert to a basic disk
3) Click Start, and then click Control Panel
4) Click Performance and Maintenance,click Administrative Tools, and then double-click Computer Management.
7) Click yes when you are prompted to delete the volume.
9) After you have deleted all the volumes on the dynamic disk,right-click the dynamic disk that you want to change to a basic disk, and then click Convert to Basic Disk.
NOTE: You must rigth-click the gray area that contains the disk title on the left side of the Details pane. For example right-click Disk 1
on Dec 31, 2009 | Computers & Internet
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Windows XP download
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
I bought DVD-RW discs but it comes up as Unknown Disc. Can you tell me what to do
If the disk in the drive shows it is a unknown disk , you must check the disk is good or bad , to check the disk , please follow the instruction,
put the dvd -rom in the drive , at the moment it shows unknown disk , select right click for properties of the disk , it shows the disk usage with a diagram , if the disk usage is on pink colour your disk is free and ready to use . otherwise the disk colour is blue in colour , it is due to manufacturing defect . it can be only cleared by replacing the disk with new one .
Mar 19, 2011 | Televison & Video
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
How tp convert a GPT hard drive to a MBR hard drive? thanks
Boot off your Vista disc and go to the Recovery options. Once inside there access Command Prompt (It is a choice in the Menu) type Diskpart.exe and hit enter. Then type Help you will see many options.
What you want to do is type 'List Disk' select the Disk you wish to convert and so forth. Basically the way to convert from GPT to MBR is in there. You can also clean all data off the disk from inside Diskpart and start over with MBR.
Commands to Convert Disks
convert mbr [noerr]
Use the convert mbr command to set the partitioning style of the current disk to MBR. The disk may be a basic disk or a dynamic disk but the disk must not contain any valid data partitions or volumes.
convert gpt [noerr]
Use the convert gpt command to set the partitioning style of the current disk to GPT. The disk may be a basic or a dynamic disk but it must not contain any valid data partitions or volumes. This command is valid only on Itanium-based computers; it may be unsuccessful on x-86-based computers.
convert dynamic [noerr]
Use the convert dynamic command to change a basic disk into a dynamic disk. The disk may contain valid data partitions.
convert basic [noerr]
Use the convert basic command to change an empty dynamic disk to basic.
http://support.microsoft.com/kb/300415
Mar 11, 2010 | Compaq Presario 1692 Notebook
Lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Nov 25, 2008 | Lenovo ThinkPad T61 Notebook
Disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
Canon BJC S300 InkJet Printer Logo
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
