Konica Minolta DiMAGE Z5 Digital Camera Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I TURNED THE CAMERA ON AND IT STOPPED WORKING AND THE LENS IS EXTENDED - THE BATTERIES ARE NEW
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Feb 24, 2011
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177119
Points
1776
It seems you have a bad lense unit, if you listen some clicks indicates that its mechanism is damaged, this can be replaced, but this is the worst case, also it can be that you're using a batteries that are new in apperance but they have been stored a long time in the store or your home, if you see their package, they have a recommended date of use, you can use a small battery checker or a DC voltimeter (both available in example from Radio Shack) to check their real state, for cameras alkaline or rechargeable batteries are recommmented, specially these last because at the end, they last more and you save some money.
2answers
Lens error, 122,1,0,0
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
My camera has a "lens error". It will not contract back and stays out in zoom...it beeps and gives me this message to start, but doesn't do anything.
2.
Thank you !!
2helpful
2answers
Lens error - restart camera how to fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Lens wil not open. Turn camera on and it gives you a "lens error"
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Thank you !!
Lens error
2.
Thank you !!
Lence error
2.
1helpful
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
2helpful
2answers
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
3helpful
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
