SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
SOURCE: ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
SOURCE: Whirlpool dryer LEQ8000JQ3 does not heat when drying
You can check which one you need to replace by using an ohm meater. You usually dont have to replace both.
SOURCE: Dryer won't start - Whirlpool LER7646EQo
IF THE DRYER DOES NOTHING AT ALL I WOULD SAY YOUR MAIN FUSE HAS BLOWN,IT IS ON THE BLOWER BOX AND IS WHITE,YOU CAN REMOVE THE BACK PANEL AND CHECK IT WITH AN OHMS METER,IF YOU GET NO READING IT IS BAD,LET ME KNOW-MIKE
