I have a wilife camera setup in my home. One indoor and one outdoor. The indoor one works just fine but the outdoor one stopped functioning. I have checked the upnp settings and done all the recommended resetting instructions. Is this camera broken?
Amazon.comhttps://www.amazon.com > product-reviews
Defender SP301-C Indoor and Outdoor Night Vision CCD Security Camera with High ... This camera has a normal resolution if they are looking for high image ...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
These units have circuit boards inside that have lights on them. These lights come on and tell you what the problem is. I have had 4 units do the same thing that yours is doing. The result has been that the compressor has gone bad. You have to get access to the control board to see the lights. There will either be one inside the inside unit or one inside the outside unit depending on exact manufacturer date.
Good luck and hope this helps.
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Press [MENU - SET ] to display the [SETUP] menu
and select [RESET].
The [REC] or [SETUP] menu settings are
reset to the initial (factory) settings.
You can download the manual following the link below:
http://service.us.panasonic.com/OPERMANPDF/DMCTZ1-MULTI.PDF
