Question about Gemini Sound Products Gemini CDJ 600 Professional Table Top Cd Player with CD/MP3/USB Capabilities and Built in Scratch Effect
Gemini cdj600 not reading mp3, wmv format - Gemini Sound Products Gemini CDJ 600 Professional Table Top Cd Player with CD/MP3/USB Capabilities and Built in Scratch Effect
Mical Caterina
  • 3,400 Answers
WMV is a video format. You need to convert to MP3
Posted on Feb 24, 2011
  • 1 more comment
  • Anonymous Feb 24, 2011
    its not reading mp3 format as well
  • Mical Caterina
    Mical Caterina Feb 24, 2011
    try a different MP3 - sometimes burned at to hi or low bit rate affects players from reading.
    hmm i will try it at 192kbps
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
I have a Gemini CFX-50 dual cd player. The left tray is not reading the cd whenever I put it in. I am getting a message "no disk". the right tray works fine. What could be the problem? Please help!
If the motor is spinning the disc, then your problem is with the laser. It either needs to be cleaned or replaced. Cleaning can be done with a regular laser lens cleaning disc, available at any store that sells electronics. A replacement lens assembly can be picked up at any store that specializes in electronics.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Oct 21, 2013 | Gemini Sound Products Gemini CFX 50 Dual...
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
Dec 06, 2011 | Gemini Sound Products Gemini CDJ 203...
Help my gemini cdmp-6000 service manual
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 03, 2011 | Gemini Sound Products Gemini Cdmp-6000...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
I want to connect Gemini Cdm-3610 to my TV can i do that and how?
You can probably patch the audio into the audio input jacks of the TV, however without a video signal there would be no picture on the TV, only audio... It is also possible that without a video signal, the TV may mute the audio inputs...
Dec 12, 2010 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Nov 27, 2010 | Gemini Sound Products Gemini Cdmp-6000...
Gemini Sound Products Gemini CDJ 600 Professional Table Top Cd Player with CD/MP3/USB Capabilities and Built in Scratch Effect Logo
191 people viewed this question
Top Gemini Sound Products Music Experts
Marvin
Marvin
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
