SOURCE: Records fine but playsback with poor picture
The video heads are dirty. Clean the heads and your picture should be fine. If a cleaning tape does not clear up the problem, try running a blank tape throught the unit from beginning to end in play mode.
Keep us posted.
Dan
SOURCE: how to fix not good video call connection always on skype
Try the ManyCam. You can always download Manycam and install it. Go to
www.google.com and in the search box type: "download.cnet.com"
(without the quotes). Click on the link to go to the site. When the
site opens look down on the left and you will see a gray area that says Find
Software. Type "Manycam" (without the quotes) in the white
search area then hit the search mirror. When it brings back your results
look for the one that says ManyCam Virtual Webcam. Down load it and
install it. Make sure you remove the check box on any junky programs it
would like to install. You only want to install ManyCam, no additions
whatsoever during the install. ManyCam is totally FREE and easy to use,
and you will always know where your webcam software is. After you install it you can go to ManyCam's website to learn how to use it on skype at: http://www.manycam.com
