Question about Whirlpool GU2400XTP Built-in Dishwasher
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
Posted by pamcguig on
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 23, 2011
Brian Watters
    Problem Solver:
  • 13 Answers
Some dishwashers (cheaper models) only have a lower wash and upper wash arm. The good ones have a mid wash arm as well.
If you overload or put large items in the dishwasher on the bottom, it will block the lower wash arm from spraying up into the upper rack, hence dirty dishes. Other than that, it could be several things, from clogged arms to no wash pressure or no rinse cycle... etc - would need more info to diagnose.
Posted on Apr 22, 2011
5 Related Answers
Anonymous
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
Larry Youngblood
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
Anonymous
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
Anonymous
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
Mike
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
My dishwasher samsung DMR777xxx, is not cleaning my dishes on the top rack and some day on the bottom. its like they have other food particle on them.
Check to make sure there is no food left at the bottom of the rack, then check to make sure you are adding the correct dishwasher soap that Samsung recommends to use with the dishwasher. If this is not working you could try using heavy duty dish washing cycle or try rinsing off your dishes before placing them into the dishwasher this reduces food buildup at the bottom of the dishwasher and helps clean your dishes better
Jul 04, 2018 | Samsung Dishwashers
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 14, 2016 | GE Dishwashers
I have a Haier HDW300SS dishwasher. The top half is cleaning the dishes normally but the bottom dishes aren't being cleaned at all. I've cleaned out the sump and checked the bottom spray arm i
Dear Sir:
See the diagrams attached and proceed according with the common sense.You can use the instruction manual in section troubleshooting.if you do no have go for free download: www. fitness. manualsonline.com or www. retrevo.com
May 07, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishwasher isn't cleaning dishes properly
try running bleach through the system.....pour some in the bottom and in the soap disp and run it
Jan 04, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Nov 25, 2008 | Dishwashers
Dishwasher wont clean
are the bottom dishes clean and not the top?could be the chopper broke
Oct 21, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
222 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Marvin
Marvin
Ekse
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
