Question about Polycom IP 550 IP Phone
Message light keeps flashing, but no message- Polycom 550
Posted by regstevenson on
Anonymous
    Scholar:
  • 44 Answers
This is usually a problem with the phone's configuration. Is this phone getting it's configuration from a network server or pbx? If so, find the configuration file for your specific extension and find this location. This example is for a phone whose extension is 2704
msg.mwi.2.subscribe=""
msg.mwi.2.callBackMode="registration" msg.mwi.2.callBack="" msg.mwi.3.subscribe="" msg.mwi.3.callBackMode="registration" msg.mwi.3.callBack="" msg.mwi.4.subscribe="" msg.mwi.4.callBackMode="registration" msg.mwi.4.callBack="" msg.mwi.5.subscribe="" msg.mwi.5.callBackMode="registration" msg.mwi.5.callBack="" msg.mwi.6.subscribe="" msg.mwi.6.callBackMode="registration" msg.mwi.6.callBack=""/>
If you are not using a network-based configuration, the phone's settings can be changed via the phone's internal web server. Open a web browser window and enter the phones' IP address, i.e. http://192.168.1.109. The default user is 'Polycom' and the pass '456'. Go to the links at the top for each line you are using and scroll to the bottom, you will see the voicemail settings there. Use the above info to fill in the correct info, save the settings and the phone will reboot.
Posted on Mar 05, 2011
- blue message light on top of handset keeps flashing even though all messages have been read - have turned the power off taken batteries out but it still keeps flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 30, 2014 | Lands Phones
What is the ID Message on the polycom soundstation 2w
If you have Polycom Sound Station 2 and you are getting NO ID Message on screen. Please do the following:
1. Press Speaker
2. 773
This should clear up the error.
Mar 21, 2013 | Polycom SoundStation
Message NO ID message followed by beep beep...
ACTUALLY MAY POLYCOM SOUND STSTION ARE NOT DAMMAGE WHEN I BUY IT.WHEN THE TYPOON IS COMING SINCE ONDOY.MY POLYCOM SOUND STSTION ARE WET COZ OF TYPOON. JUST TELL ME WHERE IS THE SERVICE CENTER OF POLYCOM
Jan 07, 2011 | Polycom SoundStation
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
One of our Polycom 550 phones keeps randomly
It is not your T1. The T1 only controls the internet, not your local LAN. How old is the phone? It could be a bad phone....What system is it installed on?
Jan 08, 2010 | Polycom SoundPoint IP 501 IP Phone
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Polycom IP 550 IP Phone Logo
3,294 people viewed this question
Top Polycom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
