Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
Posted on Feb 23, 2011
My ipod shows the apple logo n then a circle wit a red x appears
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
2436
Points
20
Follow the directions listed in the following link.
http://support.apple.com/kb/ts1463
Ipod is saying ipod is disabled
try resetting it by holding the on off button and the circle button on the bottom till the apple logo appears
3helpful
2answers
I turn the ipod on an it keeps on showing the apple an has a big red x and says www.apple.com/support/ipod
You need to restore your iPod from Disk mode:
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
  6. Open iTunes.
  7. After a few moments, your iPod will appear in the Source panel in iTunes.
  8. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  9. Click Restore.
Hope that helps.
Cheers.
My ipod says www.apple.com/support/ipod
This means there's some kind of problem with the iPod.
It might be solved by resetting or restoring your iPod. Otherwise, you'll probably need to take the iPod into an Apple store to see what's wrong.
Here's how to reset your iPod:
  1. Turn on the iPod, and make sure it's unlocked (no red is showing by the switch at the top)
  2. Press the "menu" button (at the top of the circle) and the "select" button (middle of the circle) at the same time and hold them down for at least 10 seconds, until you see the Apple logo on the screen
Here's how to restore your iPod:
NOTE: this will delete all music, etc. from your iPod
  1. Plug your iPod into the computer
  2. Open iTunes
  3. Click on "Restore" (on the "Summary" tab).
  4. Follow the onscreen instructions.
    You'll need to resync all your music etc. to get it back on the iPod after it's been restored.
If your iPod does not show up in iTunes, use these directions to put it into disk mode: http://support.apple.com/kb/HT1363
Then try the restore directions again.
Hope this helps!
My ipod 30g dont work only show www.apple technical support
The problem *might* be solved by resetting or restoring your iPod. Otherwise, you'll probably need to take the iPod into an Apple store to see what's wrong.
  2. Open iTunes
Hope this helps!
2helpful
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
My ipod comes up with the website www.apple.com/support/ipod
Try changing the firmware... slide hold switch on and off a couple of times and when hold is in off position press and hold menu and centre buttons till a silver apple logo appears.the connect to itunes and perform an upgrade or restore from under the summary tab.
1helpful
My ipod says apple.com/support/ipod
  2. Open iTunes
Hope this helps!
Problem with ipod classic
Hi! YOu need to disconnect your ipod from the pc.
Put the ipod into diskmode by following these instructions-
ht1363_2.jpg Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Ipod classic 160gb
http://fixyouripod.weebly.com/
1helpful
2answers
Apple ipod
press the centre circle button and the word 'menu' simultaniously and hold them down until the apple logo appears on the screen this shouldreset the ipod
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
