Cisco RV120W WIRELESSN VPN FIREWALL Router Logo
Posted on Feb 23, 2011
I have a cisco RV120W small business router. I am trying to access a server on the LAN from an external public IP. I have created a firewall rule but have not been successful in getting it to work. I can access the router remotely from outside the network to manage it. Please assist me in creating the firewall rule properly and to also configure any other thing that I missed.
Anonymous
Level 1:
Scholar:
  • Contributor 44 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
Scholar:
Answers
44
Questions
0
Helped
35904
Points
73
Well, you will need to do two things, make sure your ACL's are set up right and you will need an ip route statement, such as this:
ip nat inside source static tcp 192.168.1.15 80 1.2.3.4 80 extendable
In this example, any traffic from outside coming into IP 1.2.3.4 on port 80 will be forwarded to a server on 192.168.1.15 port 80.
3answers
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
1helpful
2answers
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
DMZ setup
Is there a setting in the software to select the IP address for the DMZ? I'm not sure about the firewall, but most routers need you to configure the software to actually show which IP on your network is allowed DMZ.
Port Forwarding
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Port Forwarding
Port Forwarding
Port Forwarding
Port Forwarding
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
