SOURCE: Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
SOURCE: acer pentium dual-core seagate for oem- cannot install win xpsp2
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
SOURCE: I have a Assembled Computer with Processor Intel
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
SOURCE: Hi, I'm facing following problem, can
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to [email protected]
SOURCE: I just pulled a 2.5
you should download Seatools on a working machine.....its a diagnostic program for Seagate drives.
Let it scan the drive in question, because it sounds like it could possibly be bad. The jumper settings dont come into play when hooking it up via usb!
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
for roughly $9 or $10free postage
hope this helps
