Question about Nintendo Wii Console
I have had my wii for a while and it is black and we hooked it up to our flat screen Vizio and it is only in black and white but then when i hook it up to my older tv it is in color and i cant figure out how to get color.
Posted by michellekolk on
peppy6582
    New Friend:
  • 50 Answers
Did you use the Component cables for the new tv? If you did, you need to go into the System Menu of the Wii, and change the output to Component 480p, and that should give you a color picture with a higher resolution. Hope this helps!
Posted on Mar 01, 2011
Black and white picture on wii
Double check your connections, may I ask which inputs are you using?
Feb 23, 2013 | Sanyo 42 in. LCD TV
I have a vizio hdtv and trying to hook up wii. Get it but is in black and white
Hi Friend,
Just check which TV system you have. I mean PAL/NTSC/SECAM or AUTO set it according to your country.
Good Luck.
Dec 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
I just hooked my wii & all we get is black & white
I had the same problem. Instead of going directly into the TV, I tried plugging the component cable into the auxiliary jack in my digital cable box and that seemed to fix it. Works great now.
Jul 19, 2010 | Nintendo Wii Console
Just brought a flat screen tv and put the wii on its gone on to black and white whats the problem?
Try the different inputs on your TV to see if its black and white on all of them. If thats the case then try another TV, if its still black and white then its a problem with the Wii. If it works well on another TV then you know the original TV is the problem.
May 03, 2010 | Nintendo Wii Console
Hi, can't get my Vizio TV to see the Wii Console
Through the VCR will not work very well. you need to hook directly to TV input.
Jan 12, 2010 | Vizio VO42L 42 in. LCD TV
Hooked up a wii using component cable and display is black and white. Is there some kind of menu setting for the 2nd Comp input? The 1st is connected to the cable box and working correctly.
This is not an answer persay, but you should make sure you using the correct component input. You should have 1 RGB and 1 YPbPr. The Wii would use the RGB input. To test this plug the Wii into the component jacks you have the cable box plugged into.
Jan 05, 2010 | Vizio VW42LF 42 in. LCD HDTV
I can't get my Playstation 2 or Wii to work with Vizio tv
I bought a RF Switcher Phillips SWS2325W/17 ...with this I was able to hook up my Wii...TV...DVD...and Directv...works fine...hope this helps
Dec 23, 2009 | Vizio Televison & Video
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Black and white screen
is the TV's color settings set to black and white maybe???
Jun 20, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
761 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
