Question about Kenwood KDC-BT838U Car CD Player
The people on the other end of call say I sound terrible. Re-routed mic and still does it. Could I have a bad mic?
Posted by davisdl82 on
Mike
  • 4,377 Answers
Try turning off auto gain, on the mic, often it is the "throttling" of the mic volume that causes issues...
Posted on Feb 23, 2011
Anonymous
    New Friend:
Do you have an iPhone? If so you need to upgrade the software to make it compatable, although this will not help with the iPod on the phone syncing with the deck, it will help with the phone part.
Posted on Mar 28, 2011
I NHAVE A TERRIBLE HISSING SOUND ON MIC IMPUT 1
With a mic plugged in, or with the input open? With the channel volume up or not?
2answers
Poor voice connection on yahoo im
Some times it might be problem with Network jam.
You have to check Your mic..
>Go to Action
>Call Setup
>Next
There you will find an idication tab to view your Signal Quality of Mic...
TRY to speak...There wil you find The differences...
And follow the instruction and Finish..
>Check your Jack of MIC(same time your Ear speaker Jack too)
>Change your Mic
Still same
>Tell the other one to change his mic......
Sometimes other Electronic device may create noise(Speaker and so)
Your problems Should be solved...
1helpful
Can not record with mic
For using the mic in karaoke you should mute the mic playback in windows mixer
Mic is popping
It sounds to me like you have a short in the cable. Power up unit like normal and move the wires at each end of the cable, mic end and connector end, being careful not to move the mic. If you hear popping it's a bad cable. If not, now gently shake the mic, does it pop, then it's your mic's capsule and needs replacement.
I bought this ATC 5K helmet cam it seems to have terrible sound
I have covered the mic slots up with some cardboard and essentially formed a box around it with the rear end left open for sound to enter. The rear part of the cardboard sits over the bracket as to protect the mic as much as possible from any wind noise. I use mine on motorbike and am still trialling this.
I was thinking of getting some wind protection foam (the stuff for proper microphones) and covering the mic slots with this as a test.
The covering with the card improved mine ten-fold (its just hard to explain exactly how I did it as you can see from the above).
Do you have any problems with blackout from excessive light??? This is my issue!! I have made a kind-of sunhood and will trial it later.
1helpful
Gateway Tablet m-285 Internal Mic not working
I've seen that happen once before. The mic might have disconnected from the mainboard or the mic cable might be broken. The connector is located just to the left of the screen hinge (visible after removing the power button cover by lifting the right corner of it and pulling up and out gently). It is the small connector. If it is connected, then is either the wire roken or the mic itself has gone bad. The wire is routed under the screen bezel, which has to be removed in order to gain access to the mic and mic wire. The wire breaks at the neck of the hinge, where it is subject to torsion from swiveling the screen. Hope that helps
Fred
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Kenwood receiver, and the mic input problem
Does the gtr still work on the unit? The mic jack may be bad / dirty and not routing regular audio. Try plugging the gtr cord in and out a few times. Or inspect the jack itself for tarnish, bad solder joints. Fine sand paper can be used to clean the contacts on the jack, if it's not a sealed jack.
Hope that helps...
Geno
Low sound quality, lot's of noise
the recorder does have two mic settings, hi and low. the high is great for lectures and the low is for personal dictation
Sound Input problems
What you have to do is go to your speaker volume icon in the taskbar, right click and go to open volume control and click mute microphone. If mic does not show click Advanced. This dissables the onboard mic but allows the use of your external microphone, rectifying the tinny sound.
Kenwood KDC-BT838U Car CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
