Question about Home Security
I have old micromark camera which was wired to a scart and had a 5volt adapter that attatched to wire that goes to camera.all i have left of this is 5v adapter and wire from camera with red,green,white,yellow and outer bare wire.which wires are the ones that carry power to camera and what goes where on scart?
Posted by slavenpaul on
David Legender
    Habit-Forming:
    New Friend:
  • 88 Answers
It is a special scart plug. have a look on e bay.
Posted on Jan 10, 2018
2 Related Answers
Anonymous
  • 9 Answers
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Posted on Jun 05, 2010
Anonymous
SOURCE: micromark cctv scart lead connector wiring diagram
were dose the wires go to on a black
Posted on Oct 20, 2010
CCTV cir-700sd. Where can I get rewiring information?
Leads Direct ' SCART Wiring
www.leadsdirect.co.uk/technical-library/pinouts-wiring.../scart-wiring/
A SCART connector is used to connect two electronic devices such as a television set and a video cassette recorder (VCR) or DVD player. Each device has a ..
Sep 19, 2015 | Home Security
Huskvarna Rancher 55 (~2000) no spark
could be in your switch. the ground wire needs to be attatched for new coil to work
Aug 26, 2014 | Garden
I need to install a cigarette lighter
Is it a Harley part? If so, the red wire or wire with red connector on it goes to the positive terminal of the battery. The other wire goes to the negative battery terminal. If it is an aftermarket part, or just has 2 wires, the wire that is attatched to the body (the outside) goes to ground or the negative battery terminal. The other wire goes to power or positive battery terminal.
Jun 16, 2012 | 2009 Harley Davidson XL 1200R Sportster...
Micromark cctv scart lead connector wiring diagram
Jun 16, 2010 | Home Security
Micromark wiring diagram
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I have just inherited a panasonic VCR and some old family movies that i want to watch on my samsung lcd tv. I do not have a scart lead but have the wires white red yellow on both ends, how can i connect...
I assume you mean the white, red and yellow wires have phono plugs on them? Or phono sockets, whatever - the yellow is video, the white is left audio and the red is right audio.
You can get a scart plug with these sockets on the back so you can plug them into it. You can also get a scart plug with the 3 cables coming out it with phono plugs on the end.
You should be able to get them from Amazon etc.
Nov 15, 2009 | Panasonic Televison & Video
Cctv camera wire pulled off
a simple web search for "scart socket connections" will find details of what signals each pin of a scart connector carry. however, your problem is knowing what signals the wires from your cctv camera carry. only the camera manufacturer, or a service engineer familiar with it, can tell you that.
Aug 18, 2009 | Home Security
My baterry dosen't charge
hi
try the classic electric jumpstart
take a source like an adapter or some which has an output voltage of atleast 3 times that of the battery like say if you have a AA size NIMH battery then try using a 5Volt adapter with atleast 500MA
now hold the positve wire to the +ve of the batter and negative wire to the - ve of the battery (BE SURE OF THE POLARITIES esle u'll destoy the batery completly) and hold it for not more than 10-15 secs and then quickly place for charging in the battery charger
do this in 2 - 3 charge discharge cycle
cheers
pls rate if it was any help
Jul 05, 2009 | Cameras
Can't find the scart and power adapter plus the wire has been cut
cant find power supply to my micromark camera .how do i hook up to tv and what do i need
Apr 25, 2009 | Cameras
Video
I HAVE A MICROMARK CCTV ITS A SCART TYPE IT TELLS ME IN THE INSTRUCTIONS TO PUT THE SCARTLEAD INTO THE SCART ON THE TV WHICH I HAVE DONE I AM GETTING THE PICTURE OK BUT THERE IS NO SOUND ALL I GET IS A HUMMING SOUND JUST LIKE YOU HAVE NOT TUNE IN THE TV PROPERLY I CANNOT TUNE IN THE TV AS ITS ON THE AV SO CAN ANYONE TELL ME WHY I AM NOT GETTING THE SOUND WHEN IT TELLS ME WHEN I PUT IN THE SCART THE SOUND WILL BE PICKED UP . OR COULD IT BE THAT ITS A TV COMBI VIDEO
Oct 19, 2008 | Lorex Weatherproof Color Day/Night Camera...
Home Security Logo
151 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
