From Celcius the formula is Deg. C divided by 5 multiply by 9 and plus 32.
From Fahrenheit the formula is Deg F minus 32 divide by 9 multiply by 5.
thanks, i was hoping to change the readout to display fahrenheit, i have the book but the conversion isn't published.
To change the actual readout to Fahrenheit you will have to either change the instrument system because the graduations are different - 180 degrees from freezing to boiling in Fahrenheit and 100 degrees for Centigrade. With a bit of a steady hand and perhaps the correct decals you might be able to change the characters on the gauge to reflect the new scale.
thanks. i was informed by GM that there should be a metric switch on the instrament panel but so far i cant seem to find it. seems kinda odd that a GM car would not give you the option of a fahrenheit readout
SOURCE: Changing temp display
Hold down the ambient temp button and the temp down button at the same time for 5 seconds. that should work. It has auto air right, not temp adjusting knobs that rotate.
SOURCE: the air temp reads in celsius, how do i change it
go to menu switch, select unit option, then go to temperature , select fahrenheit, if dont have menu switch then , you have go to workshop where they having software which can change units.
SOURCE: I cant figure out how to change my thermometer back from celcius to fahrenheit
Make sure that the odometer is set to miles and not kilometers. Hold the button down (while in the regular odometer setting, not the "trip odometer" setting) until it changes to miles. The temperature display will automatically change to fahrenheit. We just figured this out today.
