Question about CyberLink Power2Go
I get the message when i try to copy a CD ,,out of memory
Posted by jhnmil on
John
    Guru:
  • 811 Answers
Your virtual memory is low this is not a real problem when you have other things running in the background you do not know about. I usually increase my memory as well as when I burn things I have no windows open email automatic checking turned off as well as power options stopped so I can get a clean burn no glitches as well as it may take a bit longer but I use the slower speed rather than the fastest speed burning never fails when I do this.
How to manually change the size of the virtual memory paging fileYou must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usageYou can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box. I hope that this assisted you thanks for using FixYa! John
Posted on Feb 23, 2011
My installation disk starts to download but when it gets to about 51% and stops loading os imaging and then we get a message saying recovery coping system files failed...
Most file copy errors are RAM related. things to try are as follows:
  1. Clean the CD with a soft dry cloth and ensure no scratches or smears on data surface.
  2. If cleaning CD has no effect, then try system with individual memory modules and see if error is only associated with 1 memory module (The install error is normally copying files to or from RAMDRIVE created in RAM during install process)
  3. Run hard drive diagnostics
Dec 10, 2009 | Dell XPS 410 PC Desktop
Copy to cd
just write on cd by using cd writer
Sep 17, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I can not copy pictures to a memorex 16x/4.7gb/120 min dvd using my dell phillips dvd+rw dvd8801 device. The message I get is "windows encountered a problem when trying to copy this folder" My desktop is a...
As from your question I can say that you are only using windows default copying service. First of all you must try copying the data using some third party softwares such as Ashampoo or Nero. You can try to burn a CD/DVD image with it or simply try to write data using these softwares. Dell has been suspected of having this problem in few cases, so DVD RW drive might also be faulty. Also, there is this microsoft page which can be useful: http://support.microsoft.com/?kbid=316529
Aug 13, 2009 | Memorex (32025618) 25 Pack 16x DVD+R...
Trying to copy songs from cd to sandisk memory card without suc
Open windows media player, rip music from cd to mp3 format, then copy to phone.
Rate this.
Jun 03, 2009 | Cell Phones
Ninetendo DS keep receiving message "Could not read the data"
what ds card you are use? e.g. ds-one, supercard... etc ?
You might have a driver loose, try to re-copy all ds card driver to your memory sd, within cd support included of the pack,. or you'll need re-format your sd then copy your game at the right folder.. and try again..
Hope this helps..
Nov 30, 2008 | Nintendo DS Console
MY LAP TOP NOT COPYING DRIVER.CAB DURING MICROSOFTOS INSTALLATION
This might be a problem with your ram or memory card, try changing the ram or memory card and installing with a different CD.
Nov 28, 2008 | Intel Motherboard
Incompatible Disc Message
You need to use -R DVD disks, I used Maxell 1.4X speed disks wih no problem in a CU-VD10 berner. Hope this helps
Sep 01, 2008 | JVC Everio Share Station DVD Burner Burner
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ntdetect.com D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Computers & Internet Logo
138 people viewed this question
Top CyberLink Computers & Internet Experts
Lee Hodgson
Lee Hodgson
ThaMp3Doctor
ThaMp3Doctor
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
