Question about 3Com SuperStack 3 4228G (3C17304-US) 24x10/100 Mbps Networking Switch
How to rest t - 3Com SuperStack 3 4228G (3C17304-US) 24x10/100 Mbps Networking Switch
Posted by vijay_cho144 on
Anonymous
    New Friend:
  • 4 Answers
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Posted on Feb 28, 2011
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
Reset 2011 jeep liberty head rest
There is a little side button on side of hole where head rest connects to seat press it in and wiggle the head rest down or up into place.,.????????
May 30, 2014 | 2009 Jeep Compass
How do i take headrest off of my graco 3 in 1?
There is a gray tab on each side where the head rest slides in if you push them in it will allow you to pull the head rest out part way then push in the red head rest adjust button and it allows you to pull it the rest of the way out.
Aug 02, 2012 | Graco Nautilus 3-in 1 Car Seat
How do you move headrests on 1990 lexus
the head rest built inside the seat, you have to take car to a upholstery shop, to replace head rest. best to keep head rest because head rest was made with the seat to keep head neck stable in case of a car accident.the head rest keep you from getting broken neck on a hand on impact.head rest was made for your safety also seat belts. you need them both.
Apr 06, 2011 | 1990 Lexus LS 400
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
How do you remove the head rest from a 2004 chevy cavalier
raise the head rest all the way up. look at the plastic grommets where the head rest slides in. one should have a small tab you push in the release the head rest while pulling up. good luck!
Aug 11, 2010 | 2004 Chevrolet Cavalier
After replacing the wiper motor and linkage bushings on my Grand Voyager SE, the wiper arms stop in the straight up position when ''at rest''. Help please
Remove the arms,and place them back on where they need to go,do not turn the wipers on,do this as they set now.If the wiper blades when turned on go off the left side of the windshield ,then you will have to remove everything again,and move the wipers down in the rest position,and align everything up to the rest position,with the wipers at rest,and the motor at rest.
Jan 22, 2010 | 1992 Plymouth Grand Voyager
Prompt says dogs need to rest. dogs have rested for four hours.
Nintendogs requires you to let the dogs rest for 24 hours before you can play with them again. It's a frustrating limitation that's designed to get you to play every day rather than getting tired of the game too quickly.
Jan 04, 2009 | Nintendo DS Console
Headrest 2002 cavalier
Try this i found this at another site sounds like it should work
01. Sit in the rear seat facing the front seat you will be removing the head rest from
02. Lean the front seat back so you are looking down at the head rest
03. Pull the head rest up as far as it will go
04. Take a small flat head screwdriver and slide in into one of the holes surrounding the head rest poles
05. Move it around until you feel some resistance (if you're lucky, you might be able to move the fabric a little and actually see the clip you need to remove)
06. Wiggle the screw driver around until the clip pops out (it may take a while, but eventually it will pop out)
07. Repeat steps 4-6 for the second head rest pole
08. Once you get the head rest off, turn it upside down and you will see two very thin metal discs holding the seat belt guide onto the head rest, you need to remove these
09. Take a screwdriver and pry up on the discs
10. Once you get the discs up a little bit, put some soap on the head rest poles
11. Take a towel and start twisting the discs, continue doing this until they
Dec 29, 2008 | 2002 Chevrolet Cavalier Coupe
3Com SuperStack 3 4228G (3C17304-US) 24x10/100 Mbps Networking Switch Logo
1,221 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Sheldon Dedek
Vincent G
Vincent G
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
