You should go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
SOURCE: have 2005 BA MK11 shockwave blue falcon,paint
You may want to reference the Ford Australian Forum Boards.
There has been active discussion on owners being compensated
for particular model years due to a fault with the Shockwave paint.
On a separate note, the auto industry uses our technology for paint durability measurements (film thickness).
We have issued two press releases and have contacted Ford Senior Management on the impact of outsourcing paint applications process and quality control to the Paint Suppliers.
Press Release 1
New Books Reveal Vehicle Paint Quality Flaws Associated with Outsourcing
Press Release 2
Billions Discovered for Recovery by Automakers
We have released two books -
Basic Guide - For the Consumer
Technical Guide - For The Automaker and Auto Dealer
"MAKING IT RIGHT'
Why your Car Payments
are lasting longer than your
FACTORY PAINT JOB
We do have research data on various automakers vehicle models from the factory which shows they were released to the automaker, auto dealer and consumer below Ford's paint thickness specifications.
Low film thickness results in paint peeling, stone chipping and body rusting.
Paint applied too thick will crack.
We are advocating a "Truth in Finish Disclosure" to protect automakers, auto dealers and consumers.
You may want to advise your auto dealer on the book and do a search inside the book on either Amazon or our website for additional information.
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
