Epson Stylus C43UX InkJet Printer Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have an epson c43ux printer and haven't used it for about 3 years and a couple of days ago when i bought the ink catridges it doesn't print any other colours apart from blue and purple. The black is very fuzzy and hardly visible. What could be the problem and how do i solve it?
Level 3:
  • Epson Master 17,130 Answers
  • Posted on Feb 23, 2011
Epson Master
Level 3:
Answers
17130
Questions
0
Helped
3631708
Points
52372
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software , then you must connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Testimonial: "WoW! Fast and helpful advice. Tried as per advisement and it worked. Thank you. I am Happy and satisfied."
1helpful
When i print from my computer to laser printer, it just printed nothing. When i put paper and print direct from the printer, it did the same thing. I can still do it as scanner, but just can not print. No...
Ibuy A EPSON T-60 printer,i month ago,i use refil ,but i need daily head cleen,blue ink print iresult is not good,becuse,daily head clinig must,If daily head clean my printer can damage?
i am bangladshi, what refil drum is good for epson t 60.what is name?
Thak you SIR.
Not printing
hi...
the problem lies with the catridge(ink).you might have not fit properly.
there is a protective cover in the outlet of the catridge please check weather you removed it.
if my answer was usefull please vote me
I have refilled Black ink catridge and colour ink catridges. Black ink volume is not showing and printer is not printing. Colour ink catridge volume is recoginised. May I know what is the problome? Thank...
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
3helpful
2answers
Won't print
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
1helpful
4answers
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
1helpful
5answers
Red Flashing lights
hi dear
try to resetting your catridge
or here
http://inkjetprinterhelp.us/epsonSSC.html
oke
i hope your problem clear
good luck
Printer wont print
Are you using Genuine Epson Inks??, if you get 3 years out of a printer these days you've done well!,
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
