Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Can motorola talkabout T5720 FRS/GMRS talk with Motorola GP338 UHF?
Posted by laumenghong on
eradiostore
  • Motorola Master
  • 1,664 Answers
Your GP338 would need to be reprogrammed to one or more of the frequencies available in the T5720. If you are using the interference code eliminator, it would also need to be programmed into the GP338. Take your GP338 to your local Motorola dealer for reprogramming.
Here is a link to the user guide for the T5720, where you will find a list of frequencies: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf See page 19.
Best regards.
Posted on Feb 23, 2011
Motorola t5720: Why does my radio show 0.5 watt icon even when i am using the 1 watt channel?
It is possible the manual is wrong where it explains channels 1-7 (GMRS/FRS). When checking on line sources your example frequency on Ch 7 of 462.7125 is limited to .5 watt. http://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart
With this in mind the icon on your radio is correct, and the manual is wrong on page 19. http://shop.giantintl.com/Manuals.asp?
Best regards.
May 24, 2015 | Motorola Talkabout T5720 (7 Channels)...
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Why is not possible to communicate from T5720 talkabout to T5422 talkabout?
The two radios share no frequencies in common. The T5720 has the US frequencies classified as FRS and GMRS, between 462-467 MHz. The T5422 has the UK frequencies classified as PMR and dPMR which are in the 446 MHz range.
A list of UK frequencies can be found in this forum: http://www.transmission1.co.uk/forum/viewtopic.php?f=4&t=23400
Best regards.
Oct 01, 2012 | Motorola Talkabout T5720 (7 Channels)...
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
I want to know in wich frecuency works this radio VHF or UHF
  • Ultra High Frequency (UHF)
  • This is a FRS/GMRS radio
  • FRS (Family Radio Service) Chanel's 1-14
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  8. 467.5625
  9. 467.5875
  10. 467.6125
  11. 467.6375
  12. 467.6625
  13. 467.6875
  14. 467.7125
GMRS (General Mobile Radio Service) Channels
  • 15. 462.550
  • 16. 462.575
  • 17. 462.600
  • 18. 462.625
  • 19. 462.650
  • 20. 462.675
  • 21. 462.700
  • 22. 462.725
Regards, Tony
Apr 28, 2011 | Motorola TalkAbout T5000 2-Way Radio
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Can nice motorola GP340 talk to an FRS/GMRS w/ interference code?
If your GP340 is a UHF model, YES, you can have it programmed to match your TalkAbout radios. And yes, the GP340 has programmable privacy code capability.
If you do not know if your GP340 is VHF or UHF, you can tell by looking the model number, it will contain the following pattern: __H25RCC4AN3__. UHF models will have the letter R after the "25". VHF models will have the letter K.
When you have your GP340 programmed, the power setting will need to be turned down to the appropriate level to match the TalkAbout radios. Both for legal reasons, and also to protect your TalkAbout radios. You will not want the powerful GP340 to overpower the PA (power amp) in your TalkAbout radios.
May 10, 2009 | Motorola Talkabout T5500 (7 Channels)...
Radios will not trasmit
The Motorola T-6510 uses FRS-GMRS frequencies the TK-3130 uses 2 UHF frequencies. Unless you had the radio custom programmed to match the GMRS frequencies it will not work.
May 04, 2009 | Motorola Talkabout T5100 (14 Channels)...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
273 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
