Computers & Internet Logo
Anonymous Posted on Feb 23, 2011
This copy of Windows did not pass genuine Windows validation" This type of message is showing on my desktop I want to solve this problem.I want to exit this problem.
Anonymous
Level 3:
  • Master 844 Answers
  • Posted on Feb 23, 2011
Anonymous
Master
Level 3:
Answers
844
Questions
Helped
418700
Points
2542
Welcome to FixYa!
If you're seeing notifications that the copy of Windows that is installed on your PC might not be genuine, or that you might be a victim of counterfeit software, it's likely that your copy of Windows was not properly activated or is otherwise not genuine. To fix this, click the notification and follow the steps to either repair Windows or-if you have inadvertently obtained counterfeit software-buy genuine Windows.
If you are using Windows XP, download and install the Windows Genuine Advantage Notification Application. It will scan your operating system and will remove the annoying message if it's a legitimate copy of windows.
Download here: http://support.microsoft.com/kb/905474
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
Barbat Nae
Level 3:
  • Master 509 Answers
  • Posted on Jul 25, 2016
Barbat Nae
Master
Level 3:
Answers
509
Questions
0
Helped
315783
Points
1346
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-) ...
3answers
How to remove blackscreen wallpaper from window xp
It could be virus. Try running a full system scan.
This copy of windows did not pass genuine windows validation occurs on my desktop please solve my problem
Hello everyone
Windows genuine advantage notification is Microsoft way of punishing people using pirated copy of windows xp. Therefore, if your computer always shows you that you may be a victim of software counterfeiting, its right and you need to go and buy a genuine windows xp.
Windows genuine advantage notification occurs after you have updated your computer on the internet. Microsoft always runs a script that always checks for windows license . If your computer does not pass the test, that is when you are notified.
If your version of Windows XP is not genuine and does not pass windows genuine validation, you will not be able to download security patches from Windows Update, or install the latest version of Internet Explorer 7 and 8 and other software.
Firstly, you have to terminate the process form running on your computer secondly you have to change the name of the files that are running the process. Then change your desktop back to what you where using before.
OK This is How do solve it
notification message that this windows is not the genuine one
Right click on your task bar, click on task manager, click process tab look for the process with the name "wgatray.exe" right click on it and click end process tree, a warning message will appear click yes, the process will be terminated.
Secondly double click on my computer, double click drive C: double click windows folder, double click system 32 folder, look for two files, "wgatray.exe". When you locate the file, right click on the file and rename them to whatever you want.
Then restart your computer. Your computer should be in good state now.
IF your solution fix your problem give me thumbs
After logging into our system there is an error pop up on the Desktop stating that "You may be a victim of software Counterfeiting.This copy of windows did not pass Genuine windows Validation."...
change your windows key with the genuine serial, if you use win xp use keyfinder to change it, if you use vista or win 7 use activator to change it
I was using IE7 and I used internet to download for IE8 but whenever I both my PC, it reads "You may be a victim of software counterfeit. This copy did not pass through a genuine validation. What do...
IE8 has evidently installed Windows Genuine Advantage type validation and has judged you to have a copy of windows which is not genuine. You may buy a genuine copy of windows to fix the problem or refrain from using the software (like IE8) that has incorporated these types of checks).
1helpful
2answers
Please sofve this genuine software problem....
When you get this message it means that the licence used to install windows is not genuine.
When this happen you are supposed to call Microsoft to find out why you get the message.
To temporarily get rid of the message you can do a system restore to a date before the message came for the first time.
Regards.
5helpful
2answers
Software counterfeiting,did not pass genuine windows validation
message appearing on the screen that you may be a victim of software counterfeiting.this copy of windows did not pass geneuine windows validation. hiiii this is msg displayed on my screen
software counterfeiting,did not pass genuine windows validation problem,
Genuine windows validation
Your WINDOWS IS NOT GENIUNE to get it fix you have to buy a new windows key from microspft website or from a shop.
12helpful
5answers
This copy of windows did not pass genuine Windows Validation
It might be a pirated windows version.Contact the vendor and check for the serial number of the disc provided to you.Please do rate If this could solve your problem.
2answers
Regarding genuine windows
you will have to buy the original software..thts 6500 rupees..post ur email id and shall try and help u out!
4helpful
7answers
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
