Logitech Z-2300 Computer Speakers Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just moved my speakers around in my room and they were working perfectly before. Now only one speaker is playing and when i swap the inputs the other speaker will work fine but they other one wont. What should I do?
Sr. Pelo
Level 2:
Scholar:
  • Expert 74 Answers
  • Posted on Feb 23, 2011
Sr. Pelo
Expert
Level 2:
Scholar:
Answers
74
Questions
0
Helped
19862
Points
215
Check the mass terminated cable connecting the controller to the base speaker. This connection becomes flacky generally requiring a good contact cleaner solution being needed to be applied to restore the connections.
Go to radio shack and ask for a plastics safe contact cleaner then after disconnecting the mass terminated cable spray it liberly. Then reinsert while still wet then work in and out a few times. You can do this for all the cables connecting to the pc as well. This should restore your dead channel....hop it works :-)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
656
Points
Hi trevorreynol , I have the same problem with my speakers, were you able to get them to work?If you did, could you share, how you did it.
Anonymous
Level 2:
Sergeant:
  • Expert 158 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
158
Questions
0
Helped
44733
Points
505
Since the speakers were recently moved, start by verifying they are wired correctly. Both the small speakers should plug into the subwoofer (large speaker). On the back the outputs should be marked L for left and R for right, plug the small speakers in accordingly. The subwoofer should plug to the (usually)green jack on the computer, the subwoofer should plug into power.
1helpful
2answers
NAD 3130 one channel stopped working, tip what to do first?
May not be serious,first with good channel playing move all controls and switches on the amp,Dead spots can occur on controls especially if they are rarely used.balance controls,tape monitor switches etc so work them all.If fault doesn't clear try headphones,switched sockets can cause problems.next swap input signal leads,left to right. and if still no good try swapping over speakers left to right.STILL no sound? its the amp.Time for tools and a test meter.You can look for blown fuses but its never a good idea to replace a blown fuse without testing the circuit first.may cause further damage and put up the repair cost
1helpful
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
My right speaker is making a fuzzy noise while my left one works perfectly. How do i fix the right one?
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
I have just run a bass test and I am getting bad vibration noises from one of evp subs the sub works but seams to crash at certain frequancies
Over-driving or resonances can be unpleasant and intermittent. Decide which you have. Find some music that causes the symptom.
If you haved two identical subs the diagnosis should be easy enough. Swap them physically.
Lower the volume. Problem solved?
Move the sub around the room to see if it changes for the better or worse. Room boundaries and YOUR position relative to the speakers play a huge part in bass response.
Maybe the speaker cone is damaged or the voice coil is separating.
No sound from front left channel
Try swapping the connectors for front-left and front-right (just swap right at the back of the amp)
After the swap, does the front-left speaker work, and now the front-right is dead? If so, then it's a problem in the amp.
If not, then the problem is in the wiring and/or the front-left speaker itself.
Post back here with your findings, and we'll troubleshoot whichever part of the system is broken.
5helpful
Popping sound in the Rocoton Advent Wireless speaker
Double check your connections at the transmitter. Swap inputs to see if the popping moves to the other speaker. Popping usually means blown, however......
Audiofonics amp
Reconnect one speaker per channel and swap the RCA cables (L > R and R > L) to see if the working channel switches sides. If not, move all switches and controls to see if any are intermittent.
Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Problem with Diamond 8.4
No - sounds like the speaker/ cross over is faulty - I assume there are only one set of connections on the back - on some speakers you have 4 connections for dual wiring - and you usually bridge those out Play a piece of music with some drumming in it and you should see the midrange move a lot Just to make sure there is not a problme with the Amp - swap the speakers around - so you have a left speaker and a right speaker connected physically move the left speaker over to the rightside and connect to right side cables - and the right speaker to the left side and connect to left cables Now if the problem goes over to the other side - its the speaker thats fault if it stays on the sam side - its the amp
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
