1) LUBE the deck belt, you must do it every 1 week after use. Otherwise you will the same problem that you have right now. This is by lack of maintenance. Maybe you have WORN deck belt. 2) LubE THE rollers bearing with WD-40 NOT use for deck belt. deck belt is with 100% silicone lube. 3) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for troubleshooting motor. 4) Test the output voltage board, for input voltage board, if there are NOT the board is faulty. See the block diagram God bless you
just fixed mine take large white panel off at rear of machine look straight in below the drum two grey coloured wires going to temp sensor touched one of them and found wire was broken stripped wire back and crimped on new connector push on spade type.checked other one was ok. turned on machine hey presto error3 was gone machine ok hope this helps.
Error 3 is due to a dirty or scratched disc and error 6 is disc inserted upside down. First thing to try would be a different disc as it sounds like that one is quite damaged. If this doesn't work then you can try a software reset on the unit. The reset button is located behind the face plate on the right hand side and needs a pen or something sharp to push it in. The button needs to be held in for a good few seconds. Pressing the reset button will mean that you will lose all saved data, e.g radio stations and audio settings. Cheers, Dan
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
This can be a disc format error (try a previously known working disc) Or the laser may be out of alignment. - in this case professional repair/cleaning/alignment is recommended.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
