.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after
that insert it to your unit.,then take atleast 15 shots.,.then turn it
off.,.,then open again for you to find out if this procedure will okey.,
DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
