Samson R31S Microphone Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Anonymous
Level 2:
Sergeant:
  • Expert 298 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
298
Questions
Helped
115199
Points
566
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Can i hook up my gmw-61 to my stereo recevier
if there is a microphone jack or similar item with your wireless mics you should be able to plug it in the mic jack on your stereo and it should recognize it
How to connect SONY DYNAMIC MICROPHONE F-V40 to JBL EON 515 15IN PWRD SPKR yahoo
Several ways. Easiest way is to just hook up mic to speaker via XLR and make sure on jbl speaker switch is set to Mic not Line. ( for volume ). Ideally you would hook mic to a console ( mixer ) and come out of mixers main out (l/r) to 2 separate jbl speakers ( being powered no amp is necessary ) for stereo!
2answers
Unsure what cable to use to hook system into amp. is jack on back of unit a stereo plug or mono plug ?
Mono , they have adapters that will single out a stereo plug, But Mics are Mono
Hi... I cannot seem to capture my audio in stereo. The playback from my mic comes from one side (mono) only. How do I set it to play through both speakers? I have 2 input mics...1 one camera and my...
Your microphone has a stereo miniplug, with 3 contacts, that look exactly like headphone minijacks. You have not stated where you are trying to plug this microphone, but most computers /sound cards will accept only mono minijacks, with 2 contacts. Should you have left/ right inputs for microphones, buy a splitter adapter that will turn the stereo jack of the microphone into two mono jacks.
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
2helpful
Is a dual XLR adapter available for the MV-P612U JVC stereo mic.
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
1helpful
2answers
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
