RCA HD52W56 52" Rear Projection HDTV Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok when i turn it on the power light comes on for a bit then turns off then comes on then goes off if i keep trying for a long time it eventually comes on. but now my screen is dimmer. colors are off a bit. its not as clear as it use to be its slightly blurry compared to what it use to be.
Anonymous
Level 3:
Master:
  • Master 713 Answers
  • Posted on Feb 22, 2011
Anonymous
Master
Level 3:
Master:
Answers
713
Questions
0
Helped
107141
Points
2162
Your fuse has went bad replace fuse.
Why does battery light come on dimly, then goes out after a bit?
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Dim lights. ... Problem: Engine starts OK, but the battery does not stay charged. ... Solution #2: If the battery won't hold its charge and your engine stalls out,then it's time to ... Problem: The charge indicator light comes on while driving. .... It's OK if the wiring of the toggle switch goes to B+ or the alternator B+ ...
Alternator Problems -- Diagnosing Electrical Problems ...
hubpages.com > Autos > Do It Yourself Auto Repair
Jun 24, 2013 - Diagnosing alternator problems can be a bit tricky in certain ... After that, the alternator takes over. ... Your lights might begin to dim, you'll lose power, and then, the car ... be able to turn on the headlights, or they'll come on but very dimly. ... So before you go out and order a new battery or a new alternator, ...
What causes the battery light to be on? ' Mustang Forums at StangNet
www.stangnet.com > ... > SN95 4.6L Mustang Tech
How do i fix my tv, from standby it won't turn back on if you keep trying about 50 times it will eventually come on???
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Sony Wega power on issues after bulb replacement
Check the lamp fan (big fan behind the lamp) you can try cleaning it. Make sure you use an original lamp. Do not buy a cheap lamp from ebay or amazon.
www.aaatvservice.com
LG 37 TV WON'T STAY ON
Try changing the input device to something you are sure, works such as a DVD player. If it is same, there are leaky/dry capacitors and/or dry solders. Please refer it to a qualified service technician.
Wont turn on
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
2answers
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
