Question about Konica Minolta bizhub 250 All-In-One Laser Printer
How much is a fuser unit for a bizhub 250? - Konica Minolta bizhub 250 All-In-One Laser Printer
Posted by donaldterril on
taminol
    Sniper:
  • 62 Answers
Hi donaldterril,
The fusing unit for the Konica Minolta 250 (black & white machine) is around £225 in the UK.
Please let me know if you want to order one and I'll get you the exact price. I'm at home at the moment
and don't have access to our price list.
Regards
m-press.biz
Posted on Feb 25, 2011
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: I have bizhub c250 and
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Posted on Nov 04, 2010
Testimonial: "Thanks"
just me
  • 60 Answers
SOURCE: How much is a fuser unit for a bizhub 250? I got a
around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
Posted on Feb 24, 2011
jay sementelli
SOURCE: put in newer fuser unit but machine still says to replace
the fusers have an inline fuse soldered on the plug which resets an internal counter. if you pulled a fuser from another machine will still show up spent when putting it into another machine. you can buy these fuses and solder them on yourself. most on the fusers will last 2 to 3 cycles by doing this.
Posted on Oct 11, 2011
Minolta Di 5520 code Solution C-13f5
Yes there are 2 soft switches...... left side is for trouble reset.
Remove fuser unit from copier
Reset code co05XX
The copier needs to give you a scree with wait for warm up; if not some thing else it's going on
If you get the wait for warm up ...eventually you'll get a C05XX code
Reset and test it with the fuser unit in.
Troubleshoot fuser unit in case you get another C05XX
Tom
Apr 09, 2014 | Minolta bizhub 250 Black and White Copier
Jam in fusing unit bh 250
You need to remove the fuser to see what the block is. could be a piece of paper.
Dec 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
KONICA MINOLTA BIZHUB 501 CODE 3806?
replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 21, 2013 | Konica Minolta PRINTING - Bizhub-250...
I have a bizhub 250 and i am getting am error code c3451 i have tried the reset with the utility counter and also by hitting the number 3 after poushing the black button that is on the right side none of...
reset code is 00000000 is default if the code come back replace the fuser unit the HOT PART keep reset can cause a fire that will ruin a perfectly good day!!!!
Oct 31, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
How much is a fuser unit for a bizhub 250? I got a c3451 error.
Feb 22, 2011 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
160 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
