Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Describe your Konica Minolta bizhub C351 All-In-One Laser Printer Problem how to Assign an IP address to the machine?
Posted by amoooor_16 on
just me
    New Friend:
  • 60 Answers
go to utility/counter button
go to admin
type in password
go to tcp/ip
go to second page
type ip address in
done
Feb 22, 2011 | Konica Minolta bizhub C351 All-In-One...
Have 3 cd's that came with it. Want to print from network PC. Seems like the Printer is not broadcasting IP address. How to find the IP of the printer. Bizhub 350.
if you are using for the first time as a network printer then you should first know how to assign the "IP ADDRESS" to machine/printer. to check the ip address of the printer, simply go to " Administrator" mode, and check ip there.
all the best...........
Jun 13, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I find and reset the IP address on a Konica C351
Utility/Counter button, Administrator, 12345678 or 00000000 is password
select network setting. You can make changes to IP, DNS, Gateway, Subnet, SMTP , ect.
Apr 16, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta 250bizhub is this compatible with bt home hub 2.0 - the ip address previously set before home hub is not being allowed. is it quicker to change ip address or to change hub settings.
if you changed the hub then you have to re assign the ip. to re assign the ip, go to administrattor mode, then in this mode, go to admin 2, in admin 2, go to basic settings, then in basic settings, change the ip of the machine. consult from user manual to know how to get in "Adminstrator Mode"
Apr 07, 2010 | Konica Minolta bizhub C250 All-In-One...
I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING WITH THE NETWORK CONFIGURATION AND NOW I CAN'T PRINT, IS THERE ANY WAY TO RESET IT TO FACTORY CONFIGURATION??? ANY HELP PLEASE...
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
Feb 27, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a konica bizhub c351, I have changed my network here at the office. This IP address is 192.168.15.50 and now I need to change it to 192.168.0.50. Can you help me?
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Nov 25, 2009 | Konica Minolta bizhub C351 All-In-One...
Adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
May 01, 2009 | Konica Minolta bizhub C351 All-In-One...
How to set scan for a new person on bizhub c351
After pressing "scan," press "Direct Input," then "Scan to E-mail." That will come up with a digital keyboard with which you can enter the e-mail. You'll have to type out the whole address, as on my printer (even though I have the manual) I can't seem to find out how to save it so you don't have to type it in every time...
However, after inputting the e-mail address, press "Start" and it should scan to the e-mail.
Nov 19, 2008 | Konica Minolta bizhub C351 All-In-One...
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Mar 13, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
229 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
